Old 10-18-2009, 06:28 PM   #1
rihdrkc
Blazing Blue Yaris
rihdrkc's Avatar
Drives: 2009 Yaris 3 door Liftback
Ecometer finally dialed in
Have had the Ecometer for some time now and it was reading a bit high. Started changing the percentages tank by tank. Set at 95% now and reads 36.3, tank calculation was 36.33 mpg.
http://www.yariscentral.com/index.php
Just an old guy rockin it with you young-uns
rihdrkc is offline   Reply With Quote
Old 10-18-2009, 08:10 PM   #2
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Cool-good to know. I've got to do that too because mine has also been reading a tad high. I'm going to go right to 95 on mine next fillup and I bet it will be pretty close.
R2
-The Fitful One
Old 10-18-2009, 09:51 PM   #3
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
i never had a problem, perfect accuracy, but thats with no DFCO, just lots of neutral.
Check out my Build thread:
Old 10-18-2009, 10:43 PM   #4
rihdrkc
Blazing Blue Yaris
rihdrkc's Avatar
Did not think of that, could have been the problem.
I started down at 80%, way too low. Increased a little at a time each tank after that.
Old 10-19-2009, 12:44 AM   #5
YarisSedan
Drives: 08 Yaris Sedan
Mines set at 90 percent and still overestimates just a tad. I just mentally subtract 1mpg now from whatever it reads.
Old 10-23-2009, 02:05 AM   #6
ezhacker1
ezhacker1's Avatar
thats wierd, mine never overestimates. its perfectly accurate when no/little DFCO is used. But this tank i went with DFCO as much as i can, ecometer read 32.8 (i went a little spirited on this tank) compared to actual 33.7. Which makes sense, the ecometer reads inst. mpg lower when in DFCO, and i attribute that neutral gets you further than DFCO. So least ecometer proves DFCO works in saving gas, (its higher than ecometer reading) I still like neutral is better.
Old 10-29-2009, 08:52 PM   #7
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
Still working on getting mine dialed in -- blah.
Old 10-30-2009, 07:26 AM   #8
DevilGirl
Drives: 09 3dr LB MT
Stupid question:
What is DFCO? And what/how/why do you "dial in" the ecometer?
Old 10-30-2009, 09:26 AM   #9
127.0.0.1
Originally Posted by DevilGirl View Post
Stupid question:
Deceleration Fuel Cut Off
The ECU actually stops sending fuel at some moments, when it can do
so, and not make the car buck.
This is what Partial Zero Emissions Vehicle means.
saves gas when otherwise you'd have injectors open at idle position.
dial-in
means fill the gas tank to the first gas nozzle shutoff, and then keep
gassing up at the very same pump and same nozzle for a few weeks, and stop at the very first shutoff. do this a few times and you can calibrate the ecometer so it knows exactly how much gas is burned compared to how much it thinks is burned.
the computer estimates gas use by injector timing, revs, and other factors but you need to tell it how
much gas you really put in to make the tank full....then the meter will adjust by a percentage to give
the most accurate readings day to day
Old 10-30-2009, 06:58 PM   #10
rihdrkc
Blazing Blue Yaris
rihdrkc's Avatar
To add to the last post. The Ecometer can be fine tuned by changing the percentage. It comes set at 100%, you can raise or lower the percentage to get it to match the pump calculations.
The only stupid question is the one not asked.
FINALLY!! nickhjort DIY / Maintenance / Service 18 01-17-2009 12:09 AM
Yay finally got my YRX (photos) Spikeles Australia 15 11-12-2008 04:16 AM
I Finally Got Him!! Check out my "Chub"!! YarisGirl82 Photo-Video-Media Gallery 27 09-27-2007 11:40 AM
I'm FINALLY getting my Yaris! sherryberry New YARIS Purchase Forum 22 07-09-2007 01:08 PM
Finally! KittenRD New YARIS Purchase Forum 6 01-01-2007 10:16 PM
