Old 10-22-2009, 12:16 PM   #1
BailOut
Steals terrorist's lunch
BailOut's Avatar
Smile We finally have our home energy use where we want it!
After 2 years of effort and $2k of expenditures which included things like re-caulking every window, re-insulating all door frames, insulating every wall socket and switch, replacing the broken instant hot water recirculator, flipping over to CFLs, having a whole house fan installed, jacketing the hot water heater, reprogramming the thermostat, and a whole lot of education for and self discipline from everyone in the house, we finally have our home energy consumption right where we want it!
Below is a graphic from a tool that our utility provider offers. It measures your home's profile and occupancy against others in your region with similar metrics. For reference, we pay around $0.13 per kWh of electricity and $1.24 per therm of natural gas:
- Brian
Share the Road
Old 10-22-2009, 12:30 PM   #2
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Pretty impressive that you appear to have broken even on your expenditures over such a short period. Much more cost-effective than I would have imagined.
Reminds me that I need to replace my dinosaur of an air conditioner.
Old 10-22-2009, 01:37 PM   #3
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
whats a whole house fan?
Old 10-22-2009, 01:45 PM   #4
BailOut
BailOut's Avatar
http://www.airscapefans.com/learn-ab...al-cooling.php
Aside from its expected benefits our whole house fan also tends to help equalize temperatures between our upstairs and downstairs. This is a boon as our upstairs used to consistently be 9-11F hotter than downstairs, but now the variance is only 3-4F.
- Brian
Share the Road
Old 10-22-2009, 02:03 PM   #5
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
yeah we have that problem too in our house. the upstairs is wicked hot in the summer.
so where would that install? on the 2nd floor? does it suck air out ? or blow air in?
i'm intrigued since we plan to move our bedroom upstairs :)
Old 10-22-2009, 02:12 PM   #6
BailOut
BailOut's Avatar
It would be installed in the ceiling of the 2nd floor, near the stairwell, so that it can draw air up from the 1st floor.
It pushes air into and through the attic space (thereby pushing the hot air out of the gables), so it sucks it in from within the house.
- Brian
Share the Road
Old 10-22-2009, 02:21 PM   #7
Astroman
Modded Moderator
Astroman's Avatar
Nice! I'm pretty lucky here, with the multiple hydro power dams our elec. rate is only $.02/kwH. I still use only CFL bulbs and instead of using the heaters installed I use 2 space heaters at the 750w setting. My winter bill is only about $30-$40/mo. It's hard to do that other stuff because I rent. My new place for example only has single pane windows which sucks, but I'll be covering them with plastic, and making sure the doors have good seals. My saving just from switching to CFL bulbs has more than paid for themselves many times over
Old 10-22-2009, 02:22 PM   #8
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
nice I actually have a hole (access to the attic) right in the hallway that is just big enough for me to get through but not big enough to get anything else through. lol so the whole attic can't be used for storage. I was thinking of putting a bigger access to the attic in this small little utility room up there .. so that would be a nice place for it . and and both bedroom doors would be just a couple feet from that fan.
I'm book marking it :) maybe if plowing goes well this winter i'll set some dough aside for it :) I could easily wire it in upstairs myself or just ad an outlet in the attic.. it would eliminate the need for the ceiling fan in the (future) bedroom :)
Old 10-22-2009, 02:23 PM   #9
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
$0.0903 here
Old 10-22-2009, 02:46 PM   #10
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
i just did the energy wizard from my supplier and they said with all the things i checked off that we have in the house that our bill should be about 163 a month and in the summer we've had it as low as $75 (NO a/c) and in the winter it usually runs 100-110
so i guess we are at a good level :)
I'd like to replace the fridge with something newer .. ours just died and we picked up a side by side from CL for $300 it was in storage for 6 years but only used for a year before that. the owers purchased it at a house then started building a new house and it sat.
washer and dyer are older too it would be nice to reduce my water bill too .. but thats unavoidable with the screen printing shop here :( my water bill is usually 180ish per quarter
Old 10-22-2009, 03:59 PM   #11
BailOut
BailOut's Avatar
I like to keep things efficient on both sides of the equation, meaning I like to see a monetary break-even point within a few short years. As such the idea of replacing a working appliance with a newer one often doesn't make sense.
We've achieved the efficiency we have even with a forced gas furnace, washer, dryer and refrigerator that are all in the lowest part of the Energy Guide spectrum. Let's use the refrigerator for my cost benefit example:
Even with our high cost for power, I learned during my audit that our refrigerator uses around $55 in electricity each year. An efficient replacement model would likely use 30% less energy, costing around $38 per year. That's a savings of around $17/year. A replacement unit would cost us around $1,200, so if I replaced our working unit the break-even point would be 70 years.
The break-even for someone that pays less for power would be much longer. Of course, some older refrigerators use much more power than our $55/year, so the math can be different.
As you can see, replacing a broken or failing appliance with an energy efficient one is well worthwhile, but that isn't always true for replacing a working one.
- Brian
Share the Road
Old 10-22-2009, 03:12 PM   #12
Lafiro
Drives: 06 Yaris Sedan
Ouch I need to do something for my house!
Last year(12 months till sept) = $3580
This year 12 months till sept = $3642
Then again its a big house I guess? Two floor, finished attic, very high ceilings for second floor, finished basement. Like 5 TV's, xbox, sling box, gamecube, 1 server, 1 high p. desktop, 2 laptops, 2 fridges, 3 sound systems, lots of cable boxes, and networking equipment.
I know Im missing a LOT of stuff in that list of stuff using electricity all day.
But this amount above is with GAS included in the prices.
But I cant exactly cut down, the house it fairly new, so everything is in working order with new everything pretty much. lol
Old 10-22-2009, 03:39 PM   #13
That's awesome!
I have been monitoring my energy use for the past six months. I installed a system on my main panel that lets me see the instantaneous usage on any circuit. Just with paying more attention and replacing some older appliances we have cut our usage by 25%. We still use way too much though, as both my wife and I work out of our home. Geothermal for heat/AC and solar photovoltaic are on our short list of home improvement projects.
Old 10-24-2009, 01:27 AM   #14
Lafiro
That's awesome!
Once again I come to you for a question lol.
What system are you using? Would like to
know what in the house is using all this electricity. I swear my sister has never had the tv off in her room even during the night ever. Since it does serve as a radio as well. My mom defends her saying that's not possible. But audio recordings at 3am any random night and constant high electric bills tell me and my dad otherwise.
Having a system like the one you described would finally solve our questions and allow us to put some lines on timers hopefully.
Old 10-24-2009, 07:50 AM   #15
I started with a device from http://www.theenergydetective.com/index.html.
Their system has one set of sensors that clamp on the input wires to your electrical panel. It then transmits the data through the house wiring to their receiver unit.
Old 10-24-2009, 11:27 AM   #16
BailOut
BailOut's Avatar
That's a great tool for measuring the overall electricity usage for your home, but there's a much cheaper and easier way to get individual device measurements:
The Kill-A-Watt
That's what I used to audit our home, then waited for each month's power bill to see how our all-in per day and per month kWh usage was measuring up.
- Brian
Share the Road
Old 10-24-2009, 11:31 AM   #17
The Kill-A-Watt
Agreed.
I got totally carried away with it and built my own system, based on the T.E.D. technology where I can measure the current draw on every circuit in our panels.
Old 10-22-2009, 03:40 PM   #18
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
geothermal is awesome if i had a backhoe i'd dig my yard out completely and set something up would work nicely with that whole house fan :)
