Old 12-11-2009, 09:33 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
new noise
07 Yaris hatch..
This has always run perfect and quiet... almost silent at idle..
We just had 5 days of 15-25 below 0 at night... I started it a couple times only for a half hour or so the whole time... I went on a road trip today and have a new noise... When its idle and you rev it a little
it kind of winds down like on a slight delay after you let go of the pedal. Like a kind of whine following the engine sound...it makes the sound reving up and down..
it sounds like some cheap cars sound all the time....its not a scream
or grind..just a following delay sound with a plastic overtone...
I checked and nothing is rubbing..
I dont like this new development...I am used to perfection from the
Yaris....
What do you think...???mechanics...??
yaris9876 is offline   Reply With Quote
Old 12-11-2009, 09:39 PM   #2
Read that a couple of times, and I still get kinda lost in it. I'm guessing maybe it's the serpentine belt. They can tend to make some noise as they get older, and especially in the deep cold.
Old 12-11-2009, 10:03 PM   #3
YAR1S
YAR1S's Avatar
I feel your pain.... with the cold weather here, my yaris makes a rattle noise when you rev it.....sooo annoying.
-Jen <3
Old 12-11-2009, 11:31 PM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
hey... it happened to mine last year... it turns out to be the water pump getting seized up. It would only do it when cold at first... and then as the weather got colder.. it did it more and more...
finally replaced the water pump
Old 12-12-2009, 05:25 PM   #5
Lafiro
Drives: 06 Yaris Sedan
Really, mine does this wierd noise now that its below freezing, if I leve it in drive or reverse and just tap the gas just a bit, even with no brakes applied, it makes a wierd sound like something is really wrong.
Is this covered by warranty? Or how much is it to buy it, and how much work goes into changing it out?
Old 12-12-2009, 05:44 PM   #6
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
redo your anti freeze to 75 % concentrate instead of the standard 50%
Old 12-12-2009, 06:16 PM   #7
yaris9876
thanks dudes, I will swap out the fluid to start with... I have 170K on it so...
Very loud noise from the engine Stiv DIY / Maintenance / Service 27 10-27-2009 11:09 AM
strange noise before the car stops dani1983 DIY / Maintenance / Service 14 08-15-2009 12:56 PM
Random tire thumping noise Tonavi DIY / Maintenance / Service 6 06-06-2009 03:27 PM
Noise from the drums.... Lafiro General Yaris / Vitz Discussion 18 05-22-2009 10:49 AM
Radio noise.. need help TinyGiant In Car Entertainment + Electronics (audio / video / alarm) 13 12-06-2008 05:21 PM
