![]() ![]() Drives: 08 Yaris sedan Join Date: Feb 2009
System Setups
Im looking to get a little more bass, and loudness into my car. I dont want anything big, Im looking for one 10" sub. Will the stock speakers be able to handle it, and still sound good? Also, can i get some recommendations on what to get? TIA
Tiny Giant Clothing
Drives: 2008 Blazing Blue Yaris 3D LB Join Date: Oct 2008
i have one 10" sub in one of the custom HB woofer boxes i make.
i also still have the stock speakers. I'm very happy with the sound. Just make sure you get a HU that has a crossover so you can take the bass out of the OEM speakers and have bass only coming out of the woofer. that will make things sound much better :)
Sold the yaris... rocking an 89 vw cabriolet now :) |
If i could, I would like to keep the stock head unit. Is that possible, or do I really need to get an aftermarket unit?
#4 | |
newbie to this site again
Drives: 2007 yaris Sedan Join Date: Oct 2009
http://mobile.jlaudio.com/products_c...hp?prod_id=369 |
Tiny Giant Clothing
well if you want to run a sub i would highly suggest an after market.
The stock unit wont allow for enough tweaking to make it sound good. and you'll have to splice into your harness to get a line out for the subwoofer amp. the problem is the head unit wont have enough power to send the signal to the woofer and to the speakers .. well at least some times. i would suggest getting something aftermarket to get the best sound.
Roadrunner Jr.
I'll agree generally with that last statement. There is definately an option when it comes to using your stock source however, it's called a line output converter. As with CD players, there are good ones and junky ones.
Until recently, I wanted to use my stock source, and could have very easily. My path had changed (it has cost me beaucoup $$ to do so). I was going to be using an Autosound 2000 LOC...now it is relegated to collecting dust at the shop. That is the first company I would recommend looking at, the next one would be Soundgate. Also note...there are quite a few amplifiers that accept stock line level inputs so you can indeed just hook up the stock wiring into the amplifier. Exile and MTX are the names that come to my mind first. Questions?
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
Audio Junky
I'm running dual 8" subs in a 1.2cuft ported box w/150rms... with the stock front speakers hooked up to the stock deck.
DON'T KEEP THE STOCK DECK!!! life is sooo much easier if you have an aftermarket deck. It took me 3 days of driving around town before I finally dialed in my amp and deck so that the subs didn't sound wierd. Even then, they don't sound as good/natural as they would if I had an aftermarket deck hooked up. (there is a long story why I don't have another deck installed, and trust me, I WANT ONE installed). Anyways... Find a budget, once you have your budget then state your goals... we'll tell you if you're overly optimistic or not... which might mean you have to lower your goals or raise your budget. Budget is the key tho. As a bare minimum I'd say upgrade deck & then run sub +amp. Though, i'd really push for you to afford Deck + new front speakers + 4 channel amp & a sub. Would keep it a relatively small and simple install, and have a quality result performance wise. |
Roadrunner Jr.
yeah...Taln, if I had a DCT Z1 laying around, I'd give it to you.
There are definately options. I wouldn't say be afraid of keeping the stock deck...I sure am not. That being said, I've taken the plunge for a little aftermarket deck myself. ....four 24 bit D/A's, 4 way electronic crossover, 32 bit DSP, 31 band EQ on each side with .5 dB increments, unparalled iPod control (the deck uses it's D/A's to override the iPod's conversion), the remote is rotary dial like the iPod so it's REALLY intuitive and easy to use...all in a 1 din chassis. Fun from Japan landing on the 9th.
boydstir
i have a real clean plug and play sub floor for sale not one nicer here i have seen yet ! but its not the cheapest price but you get what you pay for and why run one 10 when you can run two 10s is my thaught $300.00 plus shipping contact me if your interested
Why only run one sub? Because thats what im looking for. Thats like saying oh you want to buy one car from me? Why buy one when you can buy 10? Thats all im looking for is one....
ShamWow. You'll be saying Wow everytime! |
#11 | |
Tiny Giant Clothing
i have one sub and its more than enough . i would recommend you go with a DVC though
Dry Bones
i decided to keep my original head unit because i actually like how it looks and where the ipod hook up is. it was definitely a lot more work to get it up and running (2 subs,, lots of wires/speakers, LOC, and figuring way more than i wanted to out), but all said and done i am more than happy with it. i put infinity speakers all around that give me great speakers and i put a (1) 10" sub in the back. it did take a while to dial it in but i feel like i get great sound out of it and everyone else is more than impressed when i turn the volume up in my little car. i do recommend upgrading the speakers while you're in there doing it... the difference is like night and day.
don't be afraid to keep the stock HU if you're willing to do a little extra work. if you're just a guy looking for some more and clearer sound out of your car it works out just fine.
can you give me instructions on hooking it up to the stock radio? kameya87@hotmail.com
![]() ![]() ![]() ![]() Drives: 2009 Meteorite 3dr Join Date: Jul 2009
I kept my stock headunit when i installed a couple subs in my yaris. I'm very happy with it. I like the look and controls of the stock stereo headunit, so it's staying.
Touchscreen DVD Navigation - 10" Bazooka Subwoofer - Kenwood Speakers - Toyota Premium Horn set AFE Pro Dry Air Filter - modified air intake box - 1ZZ-FE Throttle Body - Ultra Racing Rear Sway Bar & Front Strut Bar NST in cabin & engine bay SSK's - TWM shifter base bushings & cable bushings - Megan Racing C-Pillar Brace |
![]() Drives: 2001 Yaris T-Sport Join Date: Oct 2009
i have a 3 door 2001 yaris, I dont have rear speakers in my car so would i need to buy a splitter or anything to get a line out to go to a sub or will the hu have spare ports for me to plug the sub straight into?
Only Happy When it Rains
I have the stock speakers in my car with a inexpensive ($200) aftermarket head unit and an antique sub. It sounds pretty darn good for what I want. It won't blow anyone's mind, but it usually also went be noticed by the cops as well.
Colin Chapman disciple |
Yaris GSR LOL
Drives: 07 Yaris Hatch Join Date: Apr 2007
I ran outputs from the rear speakers to a line output and have that running signal to my amp. Spliced into the power behind the stock HU for the remote wire and it's working fine.
Due to the sale i found i have 2 12" Alpine Type Es, currently in truck boxes, and it sounds great. Only problem was not being able to properly connnect and isolate wires which caused me to blow all 4 in the car. A single 10 would work perfectly. I used to have a single pioneer 12 running 250rms from an MTX amp and that sounded great also. I would recommend staying away from "cheap" brands and just piece it together as you can afford it. If you like the sound of the factory stock speakers then keep them. Adding the amp is not that difficult if you plan ahead and spend a wooping $0.45 on proper connectors. Everything can be easily run down the passenger side since that has the easiest way in from the engine compartment that i have found. Granted an aftermarket HU would make setting everything up easier and much less custom, but it is not needed to accomplish subs. Go with what you like. The line out i used was a scosche that cost me $6 at Wal-Mart. The spool of wire i got to connect the rears to the line out was $8 for a spool of 30' (having extra wire never hurts). One thing i have noticed about the Yaris is the compete lack of sound insulation. I could clearly hear the stereo before when i only had stock speakers, now it just sounds deeper. So long as you aren't trying to hide a comp setup noise tickets are not going to be a problem.
07 Yaris hatchback purchased in Dec '06. April 2015 and 103k miles, brakes finally needed changing, original battery finally died. I love this car. |
Roadrunner Jr.
There are other options besides the Clean Sweep. You can also look at the RF 360.2.
...there's another factory source bypass, dang it the name escapes me... it has IQ on it's face. They have 3 and 5 channel versions. The Yaris and sound deadening are a must if you're truly thinking about a high level of audio performance. Stock door: ![]() Getting there: ![]() Getting there: ![]() 95% there: ![]() ![]() And done: ![]() Sound deadening on one front door. The rest is just as stupid, I promise.
| ACRONYM thread | Shroomster | Off-topic / Other Cars / Everything else Discussions | 45 | 02-15-2025 11:30 PM |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 02:15 AM |
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 04:07 PM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 11:07 PM |
