Old 06-23-2007, 10:20 PM   #1
my gauge install [updated pics 6/25]
I got the gauges in place, will post more pics when I finish the wiring this week. The cutting was scary and tedious, but I think worth the "OEM" look I wanted. These are Glowshift gauges - tach, voltmeter, and water temp:
Old 06-23-2007, 10:48 PM   #2
uncleyaris
nice job, I think the work was well worth it!
Old 06-23-2007, 10:50 PM   #3
nice, can't wait to see pics when it's wired up and lit up at night
Old 06-23-2007, 10:53 PM   #4
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
Hey with the Tach installed, how many RPM's are you getting? What are the idling RPM's? I installed an Evil 2 inch Tach in the same spot and it has a jumper on the back and I can either choose a 4 cyl., 6 cyl, or just use no jumper and all three give me different readings. I'm not sure which one's accurate. Let me know if you know :)
nickhjort is offline   Reply With Quote
Old 06-23-2007, 10:56 PM   #5
RPMs when the car is warmed up and idling should be 600-800RPM
Old 06-23-2007, 11:04 PM   #6
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Excellent work... I was thinking about doing the same with a tach only.
PetersRedYaris is offline   Reply With Quote
Old 06-23-2007, 11:04 PM   #7
uncleyaris
x2
Old 06-24-2007, 02:41 AM   #8
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Great install!
How does the inside of the dash compartment look like now? Do the cables get in the way?
Old 06-24-2007, 02:55 AM   #9
Not wired up yet, but the last pic shows the gauges from the inside...I'll do a nice little harness so the glovebox can still be used..
Old 06-24-2007, 05:23 PM   #10
smokinyaris
smokinyaris's Avatar
Drives: bad boy
its really simple how u did urs i really like how etimago has his done and i think he used DEFI's for his BALLA STATUS..................
smokinyaris is offline   Reply With Quote
Old 06-24-2007, 06:31 PM   #11
jdium
Mr Attitude
jdium's Avatar
Drives: Blazing Blue 5 Spd
Nice. How does it look at night. And what is the glare like with no shade over the gauges?
jdium is offline   Reply With Quote
Old 06-24-2007, 09:50 PM   #12
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
It would look tons better if it was angled toward the driver instead of sitting flat and flush against the glovebox cover.
Leong's NCP91 Toyota Yaris E
Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38
Stebel horns, Philips Silvervision turn indicator bulbs
TTE Lowering Springs, Camber bolts
TRD Blue brake pads
Fujitsubo Super Wagolis axleback exhaust
DC Sports header
cleong is offline   Reply With Quote
Old 06-24-2007, 10:24 PM   #13
not too much of an angle from where I sit behind the wheel, they are perfectly readable. Mounting at an angle would not be possible without some custom fabrication -- maybe later!
Old 06-26-2007, 11:55 AM   #14
ok so here's a few night shots, sorry for the crappy photography. I'll take some with a tripod and post up again. The needle is always red, the background color is changeable. There's a mode where it constantly dissolves from color to color, which will be cool for shows.
[Note: If you're going to race, don't buy these gauges, they are really cheap, the scale is completely useless and they are slow to respond. Autometer FTW. Just so you know.]
All red:
White background:
Blue background:
Old 06-26-2007, 12:00 PM   #15
Black Yaris
der Zeck
Black Yaris's Avatar
are those difficult to read at that angle? or would they be easier to read if they were straightened out?
Old 06-26-2007, 12:57 PM   #16
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
how is the glare during the day?
Old 06-26-2007, 01:10 PM   #17
they are easy enough to read, how often do you need to know how many volts you're running, etc. No glare problems - I can only think of one angle where the sun might bounce off.
Yes, pointing them more horizontally would be better -- but it's a LOT more work, IMO. I'll get to that later, probably will require some fabrication to make it look pretty.
However, the range on these gauges is just plain stupid:
voltmeter: goes to 19 volts?
tach: goes to 11,000 rpm?
water temp: goes to 350 degrees?
The fact that only a portion of the gauge range is useful to me in this car is much more of an issue than the angle at which I mounted them.
Old 06-26-2007, 01:43 PM   #18
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Perfect.
Summit, JEGS, etc. all sell little angled collar's you slip in before the gauge. They come in a few different size angles as well.
I think it looks perfect flush fit like that.
Tanabe Strut Tower Bar Install & Review [pics!] Chris07LB Wheels, Tires and Suspension Forum sponsored by The Tire Rack 57 04-07-2022 08:46 AM
Megan Header Install [pics] Chris07LB Performance Modifications 132 09-29-2010 04:41 PM
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 10:26 PM
Gauge Pod for Liftback? eight_heads General Yaris / Vitz Discussion 2 06-07-2007 11:41 AM
RPM Gauge Install rwseattle DIY / Maintenance / Service 1 04-15-2007 01:23 PM
