WFO
Drives: 2008 hb Join Date: Oct 2008
strange noise
OK i got a noise in the right front sounds like a rock in a hubcap if you know that sound, and no i don't have hubcaps, it is only at slow speed i looked in the disk guard nothing there
HELP !!! it is driving me nuts |
![]() ![]() ![]() Drives: 2009 Yaris Onyx Join Date: Dec 2009
maybe lug nuts loose, hub assembly bearing going bad?
could also be front sway bar end link?
![]() ![]() ![]() Drives: yaris1.33 Join Date: Jul 2010
I had the same it was very annoying and finally I have found the reason the bonnet rattles in the lock since the rubber backstop have been screwed all the way down ! try to screw them up maybe it will help also for you
WFO
Thanks all,
no lose lugs its not the bonnet i will check the sway bar this thing is crazy sounds exactly like a rock rolling around in a hubcap but i don't have them so i know it's not that |
![]() Drives: 2008 Black Sand Pearl HB Join Date: Oct 2008
I am having the same problem but coming from the rear (at least that's where it sounds like it's coming from). I just had it at the dealer for oil change yesterday and they stated they didn't hear anything... I swear they never hear anything. Anyways, I came here to see if anyone else was experiencing this. I am bound and determined to get to the bottom of this so I will certainly share my findings if I can get a mechanic to confirm the noise I am hearing and fix it!
WFO
I FOUND MY PROBLEM !!!!!!!
there was a small rock in the slot on the back side of the right front disk, at slow speed it was falling out and hitting the disk guard then bouncing back into the slot at speed the centrifugal force held in in place. it was just big enough that it wouldn't fall out had to pull it out. that sound was driving me nuts. at least now i know what it is if it ever happens again !!! |
| Strange noise! | mario98c | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 09-24-2010 06:49 PM |
| Strange noise? | Taiyaki | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 26 | 08-29-2009 04:05 AM |
| strange noise before the car stops | dani1983 | DIY / Maintenance / Service | 14 | 08-15-2009 12:56 PM |
| Strange Noise when accelerating! | cybertees | DIY / Maintenance / Service | 22 | 05-24-2009 09:37 PM |
| strange noise | nisyota | DIY / Maintenance / Service | 7 | 03-05-2009 09:39 PM |
