![]() Drives: Sporty Join Date: Aug 2009
Location: " When we do right no one remembers, when we do wrong on one forgets. "
Who car's are fully synthetic?
Who runs Synthetic oil in the Engine, Transmission & Diferential.
If so what's your choice. |
I love momentum.
Penzoil Platinum 5w30 motor oil. AMSoil GL4 (MTG) fluid in the trans. So far so good.
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
RLI BIOSYN 0W-20 in the engine and soon RLI BIOSYN ATF in the auto.
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it." -The Fitful One
amsoil engine amsoil tranny
![]() ![]() ![]() Drives: Blazing Blue 08 liftback Join Date: Dec 2008
AMSOIL 10w-30 Racing oil, Amsoil SVG 75-90 transmission oil
Amsoil Dot 4 Brake fluid.
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com |
The dealer said my MT ECHO has synth (or semi synth) in the tranny from the factory...
![]() ![]() ![]() Drives: '07 Yaris S Sedan M5 Join Date: Jul 2007
Engine with Pennzoil Platinum 5W-30.
Transmission with Royal Purple Max-Gear 75W-90. ------------------------------------------------ No issues.
![]() ![]() Drives: Yaris 3dr Hatch/Black Join Date: Feb 2006
Running Amsoil in the MT and GTX full synthetic in the engine. At 50K my car started getting a consistant 38 mpg and sometimes 40 mpg on the highway!
Amsoil guys....how long do you go between engine oil changes? They make a 25K and 35K and I was thinking of 35K as a once a year change. |
![]() ![]() Drives: 07 Bitchin Blue HB Join Date: Jul 2007
Amsoil changed out every 6 months or 10K miles.
According to the AMSOIL tech I talked to, about 86% of the driving in the USA falls into the "severe condition" definition. Not sure if that includes long haul Trucking or not. Most oil brands sell the product based on the maximum life available. Amsoil does the same, therefore you'll find 25000-35000 miles/1year miles advertised. Other oils advertise up to 15,000 miles/1 year. But, severe conditions require a greatly reduced oil change interval, in many cases right back to OEM intervals. Amsoil's interval decreases to 15,000 and 17,500miles respectively under severe conditions. I sell AMSOIL with the severe conditions in mind. Filtration needs to be kept up with anytime an extended drain interval is used. Many filters can be used up to the OEM oil change interval. AMSOIL has EAO filters that last up 25,000 miles in most applications, not the Yaris. The MANN filter that can be used in my Yaris is good for 7500 miles when using AMSOIL. AMSOIL no longer recommends it's EAO09 filter for the Yaris. Amsoil has restricted the EAO filter life to OEM on other Toyotas due to some unusual contaiminate amounts in these engines. No matter which brand, always change your filter whenever you change your oil.
So, if your going to use the 35,000 mile SSO AMSOIL, make sure your plan on filter changes at OEM intervals ( or 7500 with the MANN) regardles if you change your oil at that time. Determine what type of driving you do and whether the max interval really fits your driving conditions. Do an oil analysis as you near the 15000/17500 mile point if you plan on going for the max drain interval. Check out the Auto-Light Truck lookup on Trulube.com for all your fluid and lubrication needs. Maybe a bit of over info, but rather you have it.
#11 | |
07 Yaris HB 07 Road King 06 Superduty CC 05 Scion TC 01 30' Sleekcraft HP500EFI ![]() Your Local Amsoil Dealer |
![]() ![]() Drives: 2007 Liftback white Join Date: Sep 2007
Royal purple 5w-30 w/ K&N oil filter and Redline MT-90. I originally tried the Royal Purple Max-Gear 75W-90, but was grinding while downshifting, to slippery for synchros.
| Poll: Which FULLy synthetic oil do you use? | Yawesh | General Yaris / Vitz Discussion | 110 | 03-01-2010 12:39 AM |
| Synthetic Oil Questions. | Twistoffate0817 | General Yaris / Vitz Discussion | 19 | 07-15-2009 09:54 PM |
| Mini v. sedan = injury. No duh. Is this news? | jess | General Yaris / Vitz Discussion | 48 | 04-17-2009 07:46 AM |
| Say what you want, the Yaris still RULES | smartazawhipz | General Yaris / Vitz Discussion | 15 | 04-17-2009 01:36 AM |
| Breaking in a new Yaris | yaris_the_walrus | DIY / Maintenance / Service | 38 | 09-13-2007 12:02 AM |
