Old 12-12-2009, 12:20 PM   #1
JapRulezz
JapRulezz's Avatar
Drives: yaris sedan 2NZ-FE
Exclamation preformance air filter and oil change?
i just finished 8000 Km after installing a preformance cone filter
but i think that after the filter , the oil is getting dirtier more soon
when should i change my oil btw, i use mobil 1
it looks similar to this
JapRulezz is offline   Reply With Quote
Old 12-12-2009, 12:45 PM   #2
bronsin
bronsin's Avatar
The stock filter is 99% efficient at removing dirt whereas the K&N type is only 95% efficient. That means more dirt in your engine. Something to think about driving around Egypt!
Old 12-12-2009, 01:07 PM   #3
1stToyota
1stToyota's Avatar
And the 95% efficiency is probably when the K&N filter is dirty...and ready to be cleaned and re-oiled.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 12-12-2009, 08:23 PM   #4
JapRulezz
JapRulezz's Avatar
and the solution is ?..........
Old 12-12-2009, 08:45 PM   #5
bronsin
bronsin's Avatar
Have the oil analyzed. That would tell you one way or another how suitable/unsuitable it is and whether or not you want something like that in your new car. Maybe its OK. Maybe youll switch back to the stock filter when you see what the results are. Mobile One with the grit of antiquity in it...how good for your engine would that be?
Old 12-13-2009, 02:51 AM   #6
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
A dirty air filter doesn't make the oil dirty. The oil gets dirty from blow-by, gas escaping past the piston rings from the combustion chamber to the crank case. The heat in the crank case removes the hydrogen from the fuel and makes carbon which darkens the oil. as the engine wears or if you drive with spirit, you get darker oil.
Old 12-13-2009, 06:24 AM   #7
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
That 8000kms oil looks like normal color to me,after 8k it looks dark because its working.
How long before you change the oil?What do the engine designers and engineers say in the owners manual?
Old 12-13-2009, 12:39 PM   #8
JapRulezz
JapRulezz's Avatar
does this mean that the cone filter has no effect on the color my oil in a direct way ?
the manual says every 10,000 KM
Old 12-13-2009, 12:56 PM   #9
yaris-me
Learn to Relax
Correct.
Old 12-13-2009, 06:37 PM   #10
RedRide
RedRide's Avatar
The marketing dept wrote the manual and maintence schedules
All maufactures want to say their cars are more maintenance free then the compitition.
Does anyone seroiusly believe the manufacrures want their engines to last too long?
They want them to last a bit beyound the waranty so you will buy a new car.
Most of the storys about a long lasting engine concerns an owner who changed the oil more frequently than the manual suggested.
There was a time when manufactures recomended you change the oil every 6k miles. It didn't matter how long the engine lasted as the car was junk anyway after about 70k miles.
Now, there is an oil "shortage" issue and they are attempting to look "green" so, they are saying evey 5k miles.
Personally, I change oil whenever it looks and smells dirty
It's my car and I'm paying for it so, I make the decisions.
BTW, I think it's interesting to note that when most changed oil at about 3k miles, engine warenties were higher (better) on the average than they are now with longer oil change intervals becoming the norm.
Old 12-14-2009, 09:24 AM   #11
1stToyota
1stToyota's Avatar
Agreed. Grit probably isn't one of the friction modifiers that Mobil 1 wants to see in their additive package.
2008 Scion xD
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 08:18 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 05:22 AM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 02:55 PM
Nippon Oil Filter IllusionX DIY / Maintenance / Service 6 12-07-2008 03:00 AM
