![]() ![]() ![]() Drives: 2008 Sedan A/T Silver Join Date: Nov 2008
Automatic Shift Pleasure
I don't know about you, but I get a pleasure from shifting between 3rd and 4th gear on my automatic. For those who drive the auto, do you enjoy keeping the car on 3rd when climbing hills and when descending them? Do you fool around with the different gears, playing around just to see what effects you get?
I never had an auto transmission that just felt so good shifting. Maybe it's also partly due to the design of the shifter, with all the twists and turns, as opposed to the straight up and down movement. |
Its also a fun way to wear out your transmission faster.
Is it really? I notice the car shifts automatically between 3rd and 4th while keeping it on D when ascending and descending hills. Would it damage it if I kept it longer at those gears?
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
Captain,
I shift mine all the time. It is one of the most intelligent autos I've driven. I drop to 3rd and second almost every time I stop on slopes-and if I brake much at all it down shifts itself anyway, so any extra wear is minimal. The wear is offset anyway in my opinion when I lock out 4th on hills so it doesn't shift as much. The owners manual describes scenarios such as these, so evidently Toyota isn't too worried about it. IMO the biggest threat to the automatic transmission is the "lifetime" ATF. I had a tiptronic type manually shiftable auto in my Mitsu Outlander that was pretty good too, but not as smooth or fun as the Yaris. I shifted the Outlander all the time too, no problems. I like a torque converter in slippery conditions. The mitsu would allow you to take of in second so you could "numb it down" and prevent wheel spin. R2 |
That's what I was feeling, R2D2, that the transmission is made to be very shiftable. Yeah, I guess the Trans Fluid wouldn't really last forever...
Heart Up! Vitz
Drives: トヨタ Vitz Join Date: Jun 2007
a dealer said...trans fluid should be changed after 100k on the car, usually....
And i believe him, i did so on my Mitsu Mirage when it hit 103k.... |
#7 | |
USAF_SrA_E-4
if u read ur manual i think it is it tells u that the 3rd gear is actually ur Drive and the D is ur over drive and i notice that when ur in 3 it starts asking for overdrive when ur about 40 to 45
Half a Bubble Off Plumb
I like playing around with the automatic transmission, working with the throttle and speed to get it to upshift quicker or hold a higher gear longer as it climbs a hill, with the engine pulling harder at a lower speed. The control unit has some built in intelligence and can learn your preferences to an extent. Sure you have more direct control with a manual, but it's an interesting sort of negotiation.
![]() ![]() ![]() Drives: '08 Blazing Blue Yaris LB Join Date: Sep 2009
Shakespeare said the highest form of sophistication is expressed simply. That's what I feel about these cars. It's a huge undertaking to develop a fine reliable seemingly simple car like this especially at this end of the automotive spectrum.
![]() ![]() ![]() Drives: 2010 NCP91 5spd Join Date: Nov 2009
You leave it in D (OD on). The transmission can figure out the gears for itself. Overdrive isn't anything fancy or crazy. . . all it is is a fuel conserving gear that has a ratio less than 1.0. It means that it takes less than one turn of the axle to turn the wheel. If your automatic is struggling for power, it will shift OUT of OD and into 3. There is never any reason to use 3 except for engine braking and holding the gear for "racing" lol or climbing a hill to prevent gear hunting. Re-read your manual.
Drives: 2007 Yaris Hatchback Join Date: Oct 2008
#12 | |
#13 | |
Drives: 2007 4 Door Yaris Join Date: Jan 2009
Its kind of weird to put 3 more selections on the shifter if you aren't supposed to use them.. Especially in a bottom line car.....
Most of the time, but at certain angles it absolutely can not. Quote:
I live in a really hilly area. I'm hardly ever in D. My transmission works just fine at 76k miles now. I guarantee if you live in hills, you'll burn brakes 10x as fast, and your tranny 2x as fast without gear limiting. Final conclusion - done properly, limiting to L, 2, or 3, does no more damage to your transmission than not limiting, and can in fact reduce wear(from gear hunting as you put it) and definitely reduces wear on brakes. |
#14 |
Drives: 2009 TOYOTA YARIS SEDAN Join Date: Aug 2009
#15 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
Yeah, that's BS! The auto wouldn't have the option to shift gears if it was detrimental to the transmission. People have to realize it is the 21st century, and a Toyota we are talking about here!
I shift my auto all the time, mainly downshifts but occasionally to get up a steep hill. I do enjoy it, and as I have said before, you can always shift your automatic but you can't get your manual to shift on its own! Cheers! M2 |
#16 |
Michael
Drives: 07 Silver Yaris Sedan Join Date: May 2007
i love shifting my auto. do it all the time "racing" my best bud at stop lights.
#17 | |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
If you enjoy shifting so much, why not just buy the manual tranny?
#18 |
![]() ![]() ![]() Drives: '08 5-door Join Date: Apr 2009
I like the automatic because (duh) it's automatic!
If I wanted to shift gears, I'd have bought a manual. I find it more interesting to not shift gears on a hill - the transmission is partly controlled by the usual hydraulics and partly by the computer. It's interesting how it will climb a rather steep hill without downshifting or slowing down, and without lugging. However, it's your car - if you want to shift the automatic, be my guest. |
| Back to school sale Short shifter, Shift Knob, EVERYTHING is on sale! | TWM Performance | TWM Performance | 13 | 09-29-2009 10:55 AM |
| TWM Performance weighted shift knobs on sale! | TWM Performance | TWM Performance | 5 | 06-30-2009 09:58 AM |
| New shift knobs available from TWM Performance! | TWM Performance | TWM Performance | 3 | 06-25-2009 04:24 PM |
| October sale on TWM Performance shift knobs! | TWM Performance | TWM Performance | 1 | 10-31-2008 05:01 PM |
| Shift Knob for automatic | noodles009 | Cosmetic Modifications (Exterior/Interior) | 13 | 07-28-2006 05:18 PM |
