Old 01-06-2010, 08:25 PM   #1
hare
Drives: VITZ RS1500
TRD final drive
Anyone have one of these on their car?according to the graph,it should make the gear ratio less closer together,but how come TRD said it's better for 0-400m racing???anyone have some idea?
http://www.trdparts.jp/list_race-mis_ncp13.html
hare is offline   Reply With Quote
Old 01-13-2010, 09:05 AM   #2
kngrsll
Apexing Egg!!
kngrsll's Avatar
i thought about putting one in when i did my LSD, but man, looks hairy to install! you have to swap all your gears over to the other drive shaft.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 01-13-2010, 09:44 AM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
error, longer final drive or shorter final drive does not make the gear ratio closer or less closer. The gear ratio are still the same. but a longer or shorter final drive will affect your top speed.
Old 01-13-2010, 11:31 AM   #4
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
The transmission ratios don't change, but changing the final drive changes the overall gear ratio for each gear, as does changing the radius of the tire.
A taller (shorter numerically) final drive ratio will raise the potential top speed of the car (assuming you have enough power to get there and the ECU doesn't limit you), but it will ALSO raise the top speed in EACH gear of the transmission. You'll take longer to accelerate in each gear, and reach a higher top speed in each gear. The effect is exactly the same as if you put a slightly taller and more widely spaced set of gears in the transmission.
Taller gears are sometimes good for sprint races (1/4 mile, 400m, whatever) because they can eliminate a time-wasting shift right at the end. For instance, if you're timing 0-60 in some cars, you might need to shift to 3rd to get past 58 mph... where the same car with a slightly taller final drive (that should theoretically accelerate slower) can reach 60 at the top of 2nd gear up to about half a second quicker. In the 1/4, taller gears might get a Yaris through at the top of 3rd rather than shifting to 4th at the end.
Old 01-13-2010, 11:11 AM   #5
hatchbackkid82
Drives: .
Isn't the top speed determined by the ECU?
Old 01-13-2010, 11:41 AM   #6
4th in my case, and exactly right.
Old 01-13-2010, 11:44 AM   #7
Loren
What?
Loren's Avatar
Just looked at the graphs on the linked page, they back up exactly what I said. The graph is a little short on detail, but if you look at 3rd gear top speed, it's clear enough:
Bottom graph is stock 4.3 ratio: top of 3rd = <120kph
Top left graph is TRD 4.0 ratio: top of 3rd = >125kph
Top right graph is TRD 3.7 ratio: top of 3rd = >135kph
For pure seat-of-the pants fun-factor acceleration, the shortest gear you can get is what you want. For higher top speed (pointless, you already have more gear than the speed limiter will allow) or for lower rpm cruising (better economy), you want the taller gear. Anything else is just playing games with shift points.
Old 01-13-2010, 12:13 PM   #8
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Garm, were you able to evaluate how your closer gear-ratios affected your autocross? I think I recall that you put in XB gears, right? Closer ratio? I have to shift to 3rd on long slaloms to stay off the rev limiter, so I'm curious how you felt about the gearing in that type of situation.
Loren - how much does running a 205/50/15 on a 15x7 wheel change the "effective final drive" of an 08 that came with the factory 15's?
Old 01-13-2010, 12:43 PM   #9
Loren
What?
Loren's Avatar
Hell, Idunno. Do the math!
Old 01-13-2010, 01:46 PM   #10
ozmdd, I have stock gearing still. I have access to the TRD gears from Japan, but haven't decided if I want to change yet.
My rev limiter is 7000, so on my Autocross outing I was in 2nd gear for the whole run, never made it to 3rd. Tight course, though, possible shift would be needed on a course with a longer straight in it.
And the stock gearing (with the extra power) works pretty well for drag racing.
Old 01-15-2010, 12:19 PM   #11
ozmdd
ozmdd's Avatar
Thx.
FS: Authentic JDM TRD Gauge Cluster Tri Meter Cover R0ME0 Items for Sale by private party 3 03-15-2009 08:13 PM
TRD Springs Shocks and Sway Bars IN STOCK Sparks Toyota-TRD Sparks Toyota 0 03-12-2009 09:54 AM
TRD Sportivo Vios track test drive in Malaysia eTiMaGo Tracking, Racing, Auto-X Forum 10 03-05-2009 02:08 PM
TRD CAI & TRD Qiuck Shift Polar Items for Sale by private party 7 08-02-2007 06:03 PM
TRD parts? SLIK4 Performance Modifications 9 07-03-2007 06:04 PM
