Old 01-21-2010, 08:12 PM   #1
AliCLick
Drives: 2010 3DR LB, Meteorite
Installing USA•SPEC PA15-TOY iPod/Phone adapter- any concerns about airbag resetting?
This weekend I'm going to install a USA•SPEC PA15-TOY iPod adapter in my 2010 Liftback. The instructions caution that it's possible that taking apart the dashboard trim could result in requiring a reset of the airbag system. Anyone know if that's possible or likely with this vehicle? Also, the first step in the process is to remove the ground cable of the battery....really necessary in a simple install like this? Thanks.
AliCLick is offline   Reply With Quote
Old 01-22-2010, 12:26 AM   #2
It won't be an issue. As long as you don't turn on the ignition with an airbag unplugged the SRS ECU won't log a DTC.
Old 01-22-2010, 07:30 AM   #3
AliCLick
Thanks!
Update - just finished the install - it's really a breeze to remove the head unit and install this iPod/Phone adapter - less than 15 minutes to remove the dash trim, head unit, install, mount the convertor unit and drill an access hole in the glove box, and put it back together. Only things needed was a phillips screwdriver, drill with step bit, and a couple wire ties for mounting the box.
Although pricey (with $20 discount coupon at Crutchfield, I paid $129, and yes, a new head unit isn't much more...but it's more, and I have to to stop spending somewhere...), I really like how this unit integrates the iPhone into the head unit controls. It supports six custom playlists (named Toyota1xxx, 2xxx, etc) using the changer controls, and of course you can control the unit manually as always. Track and artist name appear in the head unit display, and changing tracks/playlists is smooth (I've heard it can be a little slow...maybe that's with hard-drive based iPods).
Next week, cargo net and mudguards...checking off the $$ savings that would have cost soooooo much more at the dealer (thanks TRDSPARKS.com)..
Sound quality is very good. Much superior (of course) than FM transmitter, and I think notably better quality than what you get with the aux plug. Also works fine with the TomTom Navigation app on the iPhone.
