![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
What kind ( synthetic or conventional ) ? What brand ( Pennzoil , Valvoline , etc. ) ? What weight ( 5w-30 , 5w-20 , ... ) . THANKS
![]() ![]() Drives: 2009 Toyota Yaris LE Join Date: Oct 2009
I changed it right when it hit 3000, used Mobil 1 5w30.
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
You can safely go up to 5K miles without a change. .02
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
![]() ![]() ![]() ![]() Drives: 2014 yaris 5 speed Join Date: Aug 2006
5k. and since you need to change every 5k for warranty purposes anyway, spending extra on synthetic is a complete waste of money, IMHO.
Half a Bubble Off Plumb
Roadrunner Jr.
The manufacturer's reccomendation is 5K. The dealership wants to bring you in every 3K for monetary purposes.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
Have you opened the glove box yet? the owners manual is in there and gives all the answers as to when to change the oil and what weight to use.Its every 8000 kilometers up here,as said before if you are going to change it every 5000k use regular oil.
#8 | |
![]() Oil change intervals are designed mainly by marketing. Manufactures want to claim that their cars are more maintainence free than the competition"s The also want to say their cars are more "green" and get more "use" out of oli. This is the main reason for extended oil chang intervals. So, change the oil when dirty when which is still a bout 3k mile or so. Also oil gets diry quicker in winter and can last longer in winter so, a bit of commom sense can go a long way. As far as the first oil chang...... I like to change oil in a new car at abiout 2k to flush out all the microscopic metalic particles from initial break in wear. Hey, it's your car so do not let some marketing executive tell you how to maintain it:
i deal with three different toyota dealerships. never have any of the service departments pushed for anything other than the 5K interval. my oil is still extremely clean after 5k, even this winter.
![]() ![]() Drives: 2008 Yaris Hatchback Join Date: Jan 2010
I am on my 7 toyota. I change the oil every 5k miles on 3 i put 200k miles on them and sold them and they where still running strong,I used Wal-Mart brand oil and filters.
![]() ![]() ![]() ![]() ![]() Drives: 09' Meteorite liftback Join Date: Jul 2009
we do every 5
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jul 2007
i did my first at 4, and then weened it out closer to 5 for every change after that.
![]() ![]() Drives: 2007 Yaris HB Join Date: Dec 2009
The warranty requires you to do it at 5000 miles. That's conservative and a good target. Modern oils are generally good for much more than that. If you change it that frequently conventional oils are fine, synthetic a waste of money. As far as brand, just about any will do, as long as it is the correct grade and meets today's API standards. Check your owner's manual.
For what it's worth, the only other car I ever bought brand new (besides my Yaris) got 4 month or 4000 miles oil changes, but that was only because if I planned on doing it at four, but procrastinated, I would still usually have it done by 5 months or 5 thousand miles. That car made it 230,000 miles before I got rid of it. I'm doing the same with my Yaris. |
#14 |
#15 |
You were wanting advice? you got it.
#16 |
![]() Drives: 2008 Yaris white Join Date: Dec 2009
I change the oil after 3,000 to 5,000 miles. I think the manual recommends synthetic oil, Mobile.
#17 |
#18 | |
![]() ![]() ![]() ![]() Drives: 2007 Yaris LB Join Date: Mar 2007
5% Tint Rear | Micro Image LED Ignition Light Kit |
| Planning first oil change @ 500 or 1000mi | schleppy | DIY / Maintenance / Service | 39 | 07-09-2010 06:28 AM |
| $86.44 for oil change? I feel screwed | behour | General Yaris / Vitz Discussion | 98 | 01-04-2010 07:10 PM |
| service maintance light | io3 | Yaris TS Talk | 11 | 09-22-2009 03:03 PM |
| First DIY oil change but... | derickveliz2 | DIY / Maintenance / Service | 31 | 02-02-2009 11:36 AM |
| Oil and Filter Change | jonr0613 | DIY / Maintenance / Service | 6 | 02-10-2007 07:12 AM |
