Old 02-11-2010, 08:36 AM   #1
YarisOwnersDad
Is now a Corolla S Owner
Drives: 2010 Corolla S
Intermittent failure of power locks
My son tells me that his passenger door sometimes fails to lock and/or unlock when he uses either the key fob or the power lock button on the driver's door. He has a 2009 Yaris Sedan that he bought new in March 2009.
Anyone hearing of such problems? Any TSBs out there that anyone knows of?
Tom
YarisOwnersDad is offline   Reply With Quote
Old 02-11-2010, 10:20 AM   #2
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
Tom
does it work consistently with the inside switches ?
this is the second button press where the problem occurs ?
or is it programmed to open all on one press ?
the computer can be reprogrammed on the unlock sequence from a keyfob,
maybe it needs to be reprogrammed.
127.0.0.1 is offline   Reply With Quote
Old 02-11-2010, 02:39 PM   #3
YarisOwnersDad
It sometimes doesn't respond to either the key fob or to the lock/unlock button on the driver's door.
Thanks to all for your replies.
Tom
Old 02-11-2010, 03:20 PM   #4
127.0.0.1
Tom
the power door ecu is the issue.
maybe needs a hit with a hammer (so to speak)
Old 02-11-2010, 03:34 PM   #5
YarisSedan
Drives: 08 Yaris Sedan
Hitting things with hammers from my experience usually breaks them than more than fixes them.
Old 02-11-2010, 07:27 PM   #6
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
but we still don't know for sure if its just one door or all of them if it was the ecu it would be all doors wouldn't it? it sounds more like the actuator mechanism not the ecu
RELAY.... actuators are not designed for a push function and a pull function. They only know "move"... multiple relays are used to get the whole push/pull function. When one relay is on, the other is off, each time a relay switches to on, the actuator moves... do a google search for relay wiring for door locks and you'll find a diagram of what i'm talking about.
the actuator could be bad... but I doubt it.
Old 02-11-2010, 12:19 PM   #7
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
probably a mechanical issue in one of the relays. Some times relays will get stuck.
Old 02-11-2010, 03:00 PM   #8
SailDesign
Drives: .
I knew there was a reason i had no power anything on my LB.
Old 02-11-2010, 03:44 PM   #9
DerFlosser
DerFlosser's Avatar
Drives: Yaris
Likewise....KISS
DerFlosser is offline   Reply With Quote
Old 02-11-2010, 03:07 PM   #10
YarisSedan
Its the door lock actuator. Same thing happend to my car about 6 months after i bought it. Take it to the dealer its under warrenty.
My passanger side is going out too. Going to have to take it to them also once that fails completely.
Old 02-11-2010, 07:26 PM   #11
YarisOwnersDad
I called the dealer, and the bumper to bumper warranty is good for 3 yrs/36,000. I'll just tell my son to take it in and let them fix it.
Tom
kit to install power locks? songa DIY / Maintenance / Service 21 02-12-2015 07:31 AM
Questions and advice required about power upgrading(windows & locks) W.A.S.P DIY / Maintenance / Service 10 07-22-2009 03:59 AM
Question about Yaris power locks. OtownYaris General Yaris / Vitz Discussion 3 05-14-2007 10:48 PM
power locks and alarm install acrbill In Car Entertainment + Electronics (audio / video / alarm) 1 12-01-2006 01:17 AM
