Old 01-23-2010, 03:39 PM   #1
Ranger SVO
Drives: 2010 Yaris
Cruise Control Question
Yes I read the cruise control thread on this forum, but I never saw an answer. I just bought my Yaris last week end and it does not have cruise control. I really would like to add cruise.
I did a little research here and took a picture of my column.
From what I read, all I need is the factory handle, is that right?????
Ranger SVO is offline   Reply With Quote
Old 01-23-2010, 04:18 PM   #2
Correct. You have the blue wire all the way to the steering column, so you are all set.
Old 01-23-2010, 07:29 PM   #3
Ranger SVO
Drives: 2010 Yaris
I sincerely thank you for taking the time to respond. It is appreciated
I'd go to the Toyota dealer today, but the parts department is already closed.
Old 01-23-2010, 07:36 PM   #4
No problem. As a side note, if you are buying the Cruise stalk from the dealer, you will also need to get the wire that connects it to the spiral cable.
The part number is:84633-42030
Old 01-23-2010, 08:49 PM   #5
Ranger SVO
Drives: 2010 Yaris
Thanks again
and is this the right handle??
Lot cheaper than the dealer would charge
http://cgi.ebay.com/ebaymotors/TOYOT...item27aecfc008
Old 01-24-2010, 03:37 PM   #6
b_hickman11
Drives: 08 Sedan
Does your Yaris have the power package?
Old 01-25-2010, 12:46 PM   #7
Ranger SVO
Drives: 2010 Yaris
No it does not. It is a 2010 Yaris with the Convenience Package and it has an automatic transmission
Old 02-06-2010, 11:29 AM   #8
Ranger SVO
Drives: 2010 Yaris
I just wanna say that the cruise control DOES work. I did run into one minor thing. I got my cruise switch from E-Bay and it came with the connector wire.
The problem is that the connector wire does NOT have the horn wire in it. I simply (very carefully) cut the original horn plug and removed the horn wire and pin. Again, I was very careful, I did not want to damage the pin.
Again, it works.
The moving power of mathematical invention is not reasoning but imagination.
Augustus de Morgan
Truth does not change because it is, or is not, believed by a majority of the people.
Giordano Bruno
Quick question for someone with an 08 RHD Yaris with cruise control... H3LlIoN General Yaris / Vitz Discussion 1 11-11-2009 11:43 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Looking to buy - question on cruise control Blowtorch New YARIS Purchase Forum 20 04-24-2009 10:37 PM
