Old 07-19-2009, 08:19 PM   #1
POORSHA
POORSHA's Avatar
Drives: 2008 LB
0/1 guage through firewall?
For smaller wire I know about the grommet behind the battery. How about larger wire ?
POORSHA is offline   Reply With Quote
Old 07-19-2009, 09:41 PM   #2
Brian
Brian's Avatar
It'll still fit through the same grommet behind the battery. There's a lot of room there.
Old 07-19-2009, 09:42 PM   #3
ChinoCharles
Drives: LB
With the Yaris, just drill another damn hole. LOL. I hate wiring Yarii.
Old 07-19-2009, 10:21 PM   #4
POORSHA
POORSHA's Avatar
Drives: 2008 LB
I would drill, I just don't want to hit anything. I can't believe there isn't an unused plug on the fire wall.
Old 07-19-2009, 10:53 PM   #5
Brian
Brian's Avatar
I got the plug that connects to my fog light switch through the grommet behind the battery
easily so a 0/1 gauge wire will be no problem. Why a 0/1 gauge wire though? How much power
are you planning on running through it? Just curious.
Old 07-19-2009, 11:26 PM   #6
POORSHA
POORSHA's Avatar
Drives: 2008 LB
1500 watts
Old 07-20-2009, 11:16 PM   #7
IllusionX
Drives: 07 Yaris Sedan Aero
the grommet does fit gauge 0 wire..
Old 07-21-2009, 11:46 AM   #8
POORSHA
POORSHA's Avatar
Drives: 2008 LB
Thanks for the info
Old 07-21-2009, 12:41 PM   #9
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
I don't think I saw this grommet you people talk of... do you have to yank the battery to see it, or gain access?
I've got some 2/0awg that i'd like to run, but I couldn't find a place that it'd fit... so i'm running some 4awg that I had laying around.
Old 07-21-2009, 02:44 PM   #10
Brian
Brian's Avatar
I pulled the winshield wiper assembly off because I didn't want to remove my STB to
get the battery out and it was much easier to access that way.
Old 07-21-2009, 02:49 PM   #11
IllusionX
the correct way of doing it is removing the windshield wiper/wiper motor assembly.
Old 07-21-2009, 02:59 PM   #12
ChinoCharles
Drives: LB
Well that certainly explains a lot of things. Thanks!
Old 08-09-2009, 09:47 PM   #13
POORSHA
POORSHA's Avatar
Drives: 2008 LB
It can be done
The trick to putting o/1 through the fire wall is to remove half the car first.
1) remove wipers
2) remove wiper trim
3) remove wiper motor assembly
4)remove radio trim
5) remove guage bezel
6) remove guage cluster
7) remove a pillars
8) remove dash
now you can start with the wire, solder a ring terminal on to the wire. Pull the wire from the interior to the engine bay.
done. 4+ hrs
Old 08-09-2009, 10:51 PM   #14
Slick
Slick's Avatar
Drives: '09 3-Dr
Send a message via MSN to Slick
Just to add a bit of install info... There is another unused rubber grommet on the passanger side, about 4 inches below the roof of the engine bay and about 6-8 inches from the side. It comes below the dash, which can be easily accessed by pulling the carpet back a little ways and looking up. Will give pics if asked.
Slick is offline   Reply With Quote
Old 08-15-2009, 04:54 PM   #15
goku87
goku87's Avatar
Drives: Black HB
goku87 is offline   Reply With Quote
Old 08-15-2009, 11:17 PM   #16
ryota
Dry Bones
ryota's Avatar
Drives: 2008 Yaris Liftback
Send a message via AIM to ryota
this is the one i used for my wire
Ryota
ryota is offline   Reply With Quote
Old 11-27-2009, 07:30 PM   #17
Hapa
ふざけんじゃねよ~
Hapa's Avatar
Drives: '08 Toyota Yaris Sedan Base
Send a message via AIM to Hapa Send a message via MSN to Hapa Send a message via Yahoo to Hapa
hurt my finger doing this T_T
Hapa is offline   Reply With Quote
Old 08-15-2009, 11:38 PM   #18
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
^ i used this for my fogs as well, it should be a few inches farther than the engine ECU to the passenger side, looking from in front of the car, directly left of the ECU.
Temp guage and compass in Rear view mirror Chaad32 Cosmetic Modifications (Exterior/Interior) 10 10-30-2020 08:47 PM
Running Firewall Power Wires for subwoofer MacMaster761 In Car Entertainment + Electronics (audio / video / alarm) 17 03-06-2010 04:04 PM
Resetting a Scan Guage II? CKaelin Off-topic / Other Cars / Everything else Discussions 4 11-20-2008 09:41 AM
Firewall Acess blacksan In Car Entertainment + Electronics (audio / video / alarm) 13 09-09-2007 10:54 PM
Guage face and Needles drell42 Cosmetic Modifications (Exterior/Interior) 0 07-15-2007 03:24 PM
