Old 05-19-2015, 01:25 PM   #1
keith204
Drives: 2007 Yaris LB
Serpentine Belt Replacement - Is it possible to get it too tight?
I'm about to replace the serpentine belt on my 2007 Yaris. From reading around on here, I see that if it squeals, it's too loose. However, would a belt that's too tight put bad pressure on the pulleys?
Since nobody seems to be mentioning a too-tight belt, I'm thinking that it's probably difficult to get it too tight.
Thoughts?
Keith, 2007 Yaris Liftback
YouTube: Keith's Test Garage | http://www.KeithsTestGarage.com
keith204 is offline   Reply With Quote
Old 05-19-2015, 01:28 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Yes. Over-tightening the belt can/will cause premature failure of one or more bearings, usually the water pump or alternator. Welcome to the World!
Old 05-19-2015, 02:34 PM   #3
bail_w
Drives: 2007 Toyota Yaris LB
The rule of thumb with serpentine belts is to try to twist the belt 90 degrees in the middle of the longest span - it should twist 90 degrees but no more.
bail_w is offline   Reply With Quote
Old 05-19-2015, 03:18 PM   #4
bronsin
bronsin's Avatar
Yes thats what Ive heard the 90 degree twist thing.
Which makes no sense to me because no matter how tight the belt is you can twist it 90 degrees!
I guess what I would do is tighten it so it squeeks. Then a little more. More. More. Until it stops. Then back it off a hair.
What could it hurt if it squeeks?
Old 05-19-2015, 03:47 PM   #5
tmontague
tmontague's Avatar
I tighten it so that it is very firm when pushed down in the middle of the longest span. I allow it to move a cm or so either way w/ quite a bit of force pushing on it.
Old 05-25-2015, 05:52 AM   #6
eseibel67
eseibel67's Avatar
Drives: 2007 Yaris
You can make it good and tight without damaging bearings. When it spins, the belt is looser than when it's standing still.
eseibel67 is offline   Reply With Quote
Serpentine belt squeals on cold start up after replacement. YarYarBinks DIY / Maintenance / Service 16 03-03-2017 11:04 AM
Serpentine belt replacement. Phaeton DIY / Maintenance / Service 4 01-10-2016 08:58 AM
Serpentine belt replacement - dumb question JSCIII DIY / Maintenance / Service 1 04-28-2015 06:55 PM
Drive Belt Replacement wagon DIY / Maintenance / Service 2 12-28-2014 12:24 PM
drive belt replacement and/or water pump replacement sociolog DIY / Maintenance / Service 9 02-10-2014 01:33 PM
