Old 03-29-2010, 06:14 PM   #1
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Shocks & Struts
OK so one of my shocks is dead, the rears are on their way out.
I went to my local shop and they want to put Monroe shocks and struts on, costing around $650. Are they a decent brand? Or am I better off getting something else? I don't really want to lower my car (1-2" MAX if it gets me a cheaper set).
Any suggestions let me know!
devinlamothe is offline   Reply With Quote
Old 03-29-2010, 06:20 PM   #2
XYaris
Drives: '09 Yaris LB
Struts/shocks dont lower your car. Springs do. You could get Tokico Blues, a spring with a mild drop and possibly an install done for what they quoted you. Plus you'd have a better handling car in the end. Go to,
http://shop.microimageonline.com/Suspension_c4.htm
How many miles do you have on the stock shocks/struts?
XYaris is offline   Reply With Quote
Old 03-29-2010, 06:21 PM   #3
Shocks don't affect the height of your car, the springs do that.
Tokicos $319 + $134 shipping USPS Priority = $453 USD = $462 CAD
Proven shock and a nice upgrade from stock.
Old 03-29-2010, 06:22 PM   #4
ha beat me to it
Old 03-29-2010, 06:26 PM   #5
devinlamothe
I have 161,000km or 100,000 miles.
So do shocks come with springs? Or do you have to buy them separately?
Old 03-29-2010, 06:30 PM   #6
^ that would be a coilover.
Old 03-29-2010, 06:51 PM   #7
XYaris
The springs will last the life of the car so you'll reuse them. If you just need to replace shocks/struts order the Tokico Blues and you'll be set.
ha beat me to it
Maybe the plug will earn me a micro image sticker or two in that order?
Old 03-29-2010, 06:54 PM   #8
devinlamothe
Actually you should get a sticker or something because I am definitely going to be purchasing them this Thursday (payday) lol.
Old 03-29-2010, 07:00 PM   #9
devinlamothe
Now the mechanic said that I should get the 'bearing plates' replaced at the same time. Is this necessary? He added these on the estimate at the last minute so I'm not sure if they need to be replaced.
Old 03-29-2010, 07:04 PM   #10
XYaris
Cool! See that Garm? Devin, be sure to let us know your impressions of the Blues once theyre installed. I intend to get them one day as well.
Someone else should address the 'bearing plates'. Beyond the scope of my knowledge.
Old 03-29-2010, 07:38 PM   #11
you *shouldn't* need bearing plates....whatever that is....hit many potholes?
Old 03-29-2010, 07:39 PM   #12
damn, id have sold you these stock ones i have for $200CAD plus shipping....5000km on 'em
Old 03-29-2010, 07:45 PM   #13
seth_man
seth_man's Avatar
Drives: 08 Liftback
that is really expensive for monroe shocks, for tokico's or KYB's it might be in the ball park. for those shocks his payout will be under $200. A good tech and whip those 4 shocks out in an hour flat 1.5 with an alignment.
I just looked them up and i would charge an everyday customer $448.24 for that same job done with KYB shocks with 2 hours labor @ 75/hr included. also i highly doubt you need the strut bearings replaced.
seth_man is offline   Reply With Quote
Old 03-29-2010, 08:40 PM   #14
ur talking US vs Canada pricing
but ya, its a quick-ish job, generally
but you've had how many salty winters w/ the car? 3? 4?
Old 03-30-2010, 08:06 AM   #15
devinlamothe
This is my 4th winter with the car. And ya tons of potholes up in here.
Gonna have to do some reading on bearing plates.
Old 03-30-2010, 09:11 AM   #16
sounds like BS to me though....you replace them yet, or...?
Old 03-30-2010, 01:28 PM   #17
yarrr
Drives: 07 sedan
No. OP can probably(90%) reuse the springs for a while, but they definitely don't last the life of the car.
edit:
The top of the strut is connected to the vehicle body through the upper strut mount, in some cases called a bearing plate. This bearing plate allows the strut to pivot as the wheels are turned. It must be flexible enough to handle slight angle changes and dampen movement of the upper end of the strut. This mount or bearing plate transfers vehicle load to the strut and spring, making the upper mount/bearing plate the load carrier and the lower ball joint the follower.
Ya the yaris doesn't have that. Just a solid mount on all 4 corners.
yarrr is offline   Reply With Quote
Old 03-31-2010, 07:50 AM   #18
devinlamothe
Nope I have never replaced them yet. I was going to a while back but I didn't think I had to.
So I guess I should get some springs too? I would rather replace everything I have to now instead of having to take the shocks off again to get new springs.
If that is the case, can anyone recommend any good springs to go with the Tokico's? Something that won't really lower my car that much (1" max, just because of the bad roads here).
New OEM KYB '07 Liftback Springs & Shocks (Struts) GuySmily Items for Sale by private party 7 07-25-2010 05:02 PM
Stock shocks and struts cali yaris Items for Sale by private party 4 07-11-2009 07:36 AM
FS: stock shocks + struts cali yaris Items for Sale by private party 8 05-11-2009 05:01 AM
Free for Local Pickup: Stock Springs, Shocks & Struts Violin Items for Sale by private party 4 11-14-2008 09:36 PM
FS: TRD Shocks and Struts & Tien S.Techs squibby Items for Sale by private party 3 07-02-2007 12:40 PM
