Old 04-07-2010, 05:47 PM   #1
Nuttyguy
Drives: '10 Yaris Sedan
Clinking sound coming from front at slow speeds
Recently I've noticed a clinking sound coming from the front at slow speeds. It sounds like a rock tumbling around, and stops when the wheels are moving a little bit faster. I took off the hubcaps thinking it was a rock between them and the wheel, but their was no rock in the there and it still makes the sound.
Could it be something else? It makes no clinking sound when the car isn't moving, or moving faster then like 10-15mphs.
Thanks
2010 Yaris Sedan
Nuttyguy is offline   Reply With Quote
Old 04-07-2010, 05:49 PM   #2
127.0.0.1
Thanks
2010 Yaris Sedan
nail in tire ? busted CV ?
put car in jack stands and wrangle the wheels, see if you can find it
could be a TPMS sensor broken off inside the wheel
roll the car in neutral with engine off and a friend walking alongside....listen for noize
Old 04-07-2010, 06:11 PM   #3
Nuttyguy
No nail in the tire and I don't think it would be a busted CV. The sound definitely makes it seem like something small is bouncing around in the wheel. Would the warranty cover something like this, even if it's just to check it? First issue I've had with the car. It's also my first new car.
Old 04-07-2010, 09:51 PM   #4
127.0.0.1
dealer should check it for free, yes.
Old 04-07-2010, 10:42 PM   #5
YarisSedan
Drives: 08 Yaris Sedan
ive seen a rock stuck in the vein in the center of a rotor before making that noise that goes away at faster speeds.
Have you driven over any construction sites recently? To try to isolate the noise maybe jack up each wheel indepenently and spin the wheel by hand and listen for the noise.
Old 04-08-2010, 08:29 AM   #6
kaly5
Drives: 07 blazing blue hatch
This has happened twice to me in the last two years. There is a very small opening at the top of the brake backing plate where a stone can get between the backing plate and enter the hub of the rotor. Once the stone gets in it can't get out because there is no opening on the bottom. The tinging noise you hear is the stone bouncing against the backing plate.
Remove the wheel, remove the caliper (only two bolts hold it on) and remove the rotor. The stone will fall right out. I just had to do this last week.
kaly5 is offline   Reply With Quote
Old 04-08-2010, 06:24 PM   #7
mimelio
Drives: NONE
A lose hubcap can make noise like that too. My 2002 Echo did that a couple of times
mimelio is offline   Reply With Quote
metal snapping sound on front end when braking... marcus General Yaris / Vitz Discussion 25 11-26-2010 11:29 AM
Weird rattaling sound coming form the windshield?!? YarisSedan DIY / Maintenance / Service 7 12-25-2009 10:28 PM
Coilovers - creaking sound from passenger front? Gideon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 03-16-2009 04:20 PM
"Tok" Sound when braking at low speeds (less than 10kmph) buchieboy General Yaris / Vitz Discussion 30 02-16-2009 07:50 PM
