Old 04-17-2010, 05:24 PM   #1
phyrefighterjay
Drives: 07 yaris sedan
Metal on metal rotating wheel noise
My yaris is making a rotating metal on metal noise and it is coming from the front drivers side wheel. It's not the brakes ...the rotating metal on metal noise remains when the brakes are pressed. The pads and rotors are just fine with lots of pad left. My best guess is bad bearing however we are traveling and even after all these miles the hub is cool to the touch and there is no movement when I shake tire hard *Could it be anything else but the bearing? The rotating metal noise is terrible! Please help*
phyrefighterjay is offline   Reply With Quote
Old 04-17-2010, 07:31 PM   #2
Have you rotated the wheels while up on a jack to listen for scraping?
Could be the shield mounted on the inside of the front rotars has been bent.
Old 04-17-2010, 10:34 PM   #3
YarisSedan
Drives: 08 Yaris Sedan
Jack up each side and rotate the wheel. Feel for any "crunchyness" in the wheel when its rotated. Grab the wheel and feel for play up and down mostly and some side to side. Any movement that is abnormal would indicate a bearing. You may have hit a very large pothole and its taken its tole.
Old 04-18-2010, 06:26 PM   #4
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
That is most likely what it is. It happened to me a while back when a place I took it to have break work done didn't put the shield back in properly. They just bent it back and it has been fine ever since.
devinlamothe is offline   Reply With Quote
Old 04-18-2010, 06:31 PM   #5
Yariz
Drives: Yaris 3dr Hatchback
This can happen (has to me)
or
It can be a bearing (easy to replace)
Or
Could be scrapers/metal in brake system.
Yariz is offline   Reply With Quote
Old 04-18-2010, 08:05 PM   #6
steven-37
Drives: 09 Yaris 3D Hatch
Hi,
Could the problem be similar to this ?
This guy ran over a mattress and decided to keep going. The ensuing jumble finally whipped around enough to put a tear in the gas tank, the subsequent lack of fuel is what finally brought this vehicle to its knees.
It had still managed to drive 30 more miles decently with a 60lb tangle wrapped around the driveshaft.
This genius complained that the vehicle had a "shimmy" when driving it high speeds.
This is what the dealership found..............
steven-37 is offline   Reply With Quote
Old 04-19-2010, 11:07 AM   #7
Falconeer
Bayou Blue Pearl.
Drives: Yaris 5D Liftback Full Options
LOOOOOL THIS IS THE BEST THING SO FAR TODAY.
BOSCH 8000k HID Headlights, BOSCH 8000k HID Fog Lights. BOSCH Horn. 30% tint all round. 70% Tint mirror-finish tint on front wind shield. TRD Leather Shift Knob, Leather Steering Wheel, TRD Emblem. Height adjustable driver's seat is cool! and... That great armrest from ebay
Falconeer is offline   Reply With Quote
Old 04-19-2010, 12:31 PM   #8
1stToyota
1stToyota's Avatar
With car jacked up, if it's a wheel bearing you should be able to feel a little bit of play in the wheel, with your hands @ 6 & 12 o'clock on the tire. And too, while driving you should be able to confirm if it's a wheel bearing by giving the steering wheel a few little quick, small jerks (exercise a little caution when doing so)...the noise you're hearing will change when moving the steering.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 02:41 PM
Clicking noise when jerking steering wheel side to side/hit bumps left side eii DIY / Maintenance / Service 8 03-22-2010 07:46 PM
Humming noise when turning the steering wheel!! Help?? mhkritzinger DIY / Maintenance / Service 7 09-28-2009 09:27 AM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 11:16 AM
forged rims Vs. alloys red-jdm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-23-2007 09:30 PM
