Old 04-09-2010, 03:30 AM   #1
A1phazu1u
A1phazu1u's Avatar
Drives: Black 07 Toyota Yaris Sedan
Sand Blasting
So. I've got a set of old rims i want to restore because the previous owner did a crappy job of spray painting them.
I want to know if anyone, in socal preferably, that can quote me the price for sand blasting Four Rims. Thank you in advance.
A1phazu1u is offline   Reply With Quote
Old 04-09-2010, 12:12 PM   #2
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
If you know anyone with an air compressor, you can buy a sandblaster and the blasting media for cheap. You'll spend under $50 for it. Get a good set of goggles and a respirator too. Breathing that stuff is bad.
I sand blast stuff at home all the time (especially wheels).
Old 04-09-2010, 01:01 PM   #3
severous01
harbor freight has a blaster kit you should be able to use twice maybe 3 times for about 25 bux...comes with media.
also, matco/mac/snapon have a good kit. and it uses media...i think it's some sort of peroxide pelets...but it's cheap. the gun is 50 bux and media is 10 bux a bag...25lb bags i think.
but if you want to have someone do it, take it to a local machine shop...not a mechanic. even a head shop or performance shop should be able to point you in the direction. they'll prob do it for 10/ea
Old 04-09-2010, 03:03 PM   #4
i do mine with some wire brush attachments for my drill from home depot...
Old 04-09-2010, 03:23 PM   #5
schleppy
I love momentum.
schleppy's Avatar
i do mine with some wire brush attachments for my drill from home depot...]
That is a damn good idea! Can you link me to the wire brush you use?
Old 04-09-2010, 03:45 PM   #6
can't seem to find them online
just go and ask for wire brush attachments for drills....
i use several different kinds to get into all the nooks/crannies....but i spent maybe $30 on brushes....i think i have 4 or 5 brushes
Old 04-09-2010, 04:50 PM   #7
TRDMarty
Your other option can be your local powdercoating service.
They have to media-blast (similar to sandblasting) prior to the powdercoating
process. They even might have a color you could be interested in as well. My experience of affordability is if they are already running the color you choose then it's pretty cheap for them to do and they usually say to you cash or beer money for the job and off their books. They usually have a large selection of colors. You ask about the cost, if good then decide if there is a color, if good then drop off your wheels. They blast them perfectly clean then powdercoat them.
You pick them up shiny & new looking with a very durable finish. Just mount & balance the tires & enjoy.
Old 04-09-2010, 05:06 PM   #8
my experience is that powdercoating, while better, is north of $200/set potentially more if they do a proper media blast. PLUS you can't have your tires on the wheels ($10 to unmount, $60 to remount and balance) and you obviously can't do it in a day
ive done several sets of wheels at this point and i can get them wire brushed, cleaned, primed, painted, and cleared in about 5-6 hours if i need to. wire brushes are $30, paint is about $25 for 3 cans of paint (primer, paint, clear (which you will maybe use half of)) and painters tape and old newspaper to mask off the tires is maybe $8 if you have to buy a newspaper
you can reuse the wire brushs to clean your calipers, drums, or any other metal part that rusts (i did that last week, actually) and you still have half a can of primer, paint, and clear if you want to do more wheels later
Old 04-11-2010, 11:28 PM   #9
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
is there a super chemical to soak the rims in to remove the paint? that would be nice :)
Old 04-12-2010, 06:37 AM   #10
A1phazu1u
A1phazu1u's Avatar
paint stripper....
Anyway. i'm buying some super advans sa3r for dirt cheap, but the previous owner did a shystie job on painting them with a rattle can. Point is i don't have the time or space to do the job myself, and on top of that i have a small budget if you know what i mean. Its an investment, so any recommendations would be nice for so-cal powder coating sounds like a good idea but pricey.
Old 04-12-2010, 12:10 PM   #11
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Sent you a PM.
Old 04-12-2010, 02:15 PM   #12
YarisSedan
Drives: 08 Yaris Sedan
You can buy a can of paint stripper from o rileys. Its a few bucks you spray it on and in about 10 seconds the paint will bubble up and you just hose it off with water and comes off in chunks. Just repeat till you are down to bare metal. Then procede to primer and paint.
Old 04-12-2010, 03:40 PM   #13
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
As far as the stuff at Hardor Freight. I made the mistake of buying a gravity feed blaster that's a piece of crap. It's a gun with a hopper attached to the top that you connect to a compressor. It sucked azz. Don't ever buy it.
Old 04-12-2010, 05:19 PM   #14
YarisSedan
From my experience with harbor freight your okay as long as the tool has no moving parts. Screwdrivers, sockets, wrenches hammers etc.
