![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
What is this rusty looking thing?
Hi,
I just finished taking out and putting back in all my seats, and noticed that on several of the seat bolts that go down into the floor/bottom of the car, the bolts came out with dirty looking rust on them. Does this indicate that the bottom of the car is rusted? Its only 33 months old.. |
#2 | |
USAF_SrA_E-4
Any pics?
No pictures, I put the bolts back in after spraying with anti rust.
![]() Drives: 2007 Yaris Sedan (Aero) Join Date: Mar 2010
It is just surface rust. I work in a car factory and there are certain bolts that the manufacturer want to "rust" and "seize" up so that they don't come loose and fall out. This doesn't mean that the under of the car is rusting, these bolts are designed to do that.
![]() ![]() ![]() Drives: 2009 Yaris Onyx Join Date: Dec 2009
#6 | |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
LOL. In all my vehicles, the bolts the manufacturer doesn't want to come out have a threadlocker compound on them, or other retainer. rust -cannot- be part of the equation because there is a good number of cars driven in dry climates which will never see surface rust. so you are going to count on rust ? fail. |
seats bolts usually stick out the bottom of the car and are exposed to the elements
it is just normal crud. if you are concerned, pop them, lather with grease, replace |
Bolts that fasten seats to the floor boards are often secured with a threaded, steel insert that does go straight through the floor board.
In other words it's possible that when inserted, the ends of the bolts will indeed be exposd to the elements. As we all know, it does not take too long for any iron or steel to rust. This is normally not a problem as seats are one thing that is rarely removed except by some realitively few that install custom seats. |
![]() Drives: 2008 Yaris Sedan Join Date: Mar 2010
I work for Toyota in Georgetown KY, building Camry's, Avalon's and Venza's. I can tell you that seat bolts on Toyota's do not go through the floor pan. The bolts that we use are coated with a rust colored substance that works similar to Loc-tight. The bolts are shot with a control tool to a specific torque. They are considered a safety regulated item. I can also tell you that coating these bolts with grease is NOT advisable! Grease on the treads will cause the bolts to stretch and not hold the proper torque.
#11 | |
last time i pulled the rear seat + the metal frame that bolts to the floor, they were rusted. |
Yep, there were only some of the bolts that were rusted. I thought they were only the ones near the wheel wells, didn't quite keep track of it, but indeed, the ones on the bottom rear seat frame had rusted tips.
#14 | |
not all toyota's are the same my 4runner seat bolts holes all poke through the bottom, but that bottom is very high and only rarely do they get wet or crud on them. after 11 years they have very little rust, but yes they go right through to open air under the vehicle |
#15 |
![]() ![]() ![]() Drives: 07 liftback Join Date: Nov 2008
yeah, I've taken out all my seats in my car, and almost every bolt leaves a nice big hole that I can look at the asphalt through....
they go through the floorboard.... |
| Weird thing..my left wheel sits in more than the right | ezhacker1 | Cosmetic Modifications (Exterior/Interior) | 33 | 06-21-2010 03:43 PM |
| Can someone tell me how to call this thing? | window_lee | General Yaris / Vitz Discussion | 3 | 10-26-2009 08:21 PM |
| Which friggin' transmission is in this thing? | H3LlIoN | Performance Modifications | 19 | 08-20-2009 08:34 AM |
| Did i do the right thing? | strider86x | General Yaris / Vitz Discussion | 9 | 10-05-2006 03:52 AM |
| What is that circle thing? | Mad Munchkin | Photo-Video-Media Gallery | 13 | 09-26-2006 02:27 PM |
