Colin Richardson
Drives: Yaris Sr 1.8 Dual VVT-i Join Date: Nov 2009
Oil light
Turns on and off on sharpe turns and roundabouts ! any1 else have this problem ?
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
No I don't. I would check your oil level and add more to put it on the full mark.
Making a decision without following it with an action is still a fantasy. |
Audio Junky
simple solution... STOP TURNING... geez.
are you sure its the oil light?
Mine does this when my windshield washer fluid is low |
![]() ![]() Drives: '10 3D Liftback Join Date: Mar 2010
Colin Richardson
Topped it up 2day with 1ltr its hard to gettin a clear reading
Was it low to start with?
Hard to get a clear reading on the dip-stick? Let the car sit for a while. Pull the stick and wipe it clean. Stick it in, pull it out again. Should give you an accurate reading. If you've just poured in cool oil, it can sometimes take a bit for it to work its way down into the pan. Best to let it sit and re-check to make sure you didn't over fill it. Did adding oil take care of your light issue? |
Colin Richardson
i added 2ltr.. and it has took care of the light issue.. but im scared ive damaged the engine although everything seems ok part from a noise from my exhaust i think wen i start up :S getin tht looked at on wednesday. the reading is fine on the dipstick now and doesnt looked like ive filled it up 2 much
It was down two full liters? That's a lot. You should check carefully for a leak.
Half a Bubble Off Plumb
Yep. So far, mine doesn't drop the level discernably over a 5000 mile oil change interval.
Maybe you might check this thread out....
Oil light coming on and off |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 08:18 PM |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 05:22 AM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 02:50 AM |
| Intermittent low oil pressure light. | Inspector14 | DIY / Maintenance / Service | 23 | 03-29-2010 02:46 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 09:16 PM |
