Old 02-28-2013, 11:12 PM   #1
Yarflana
Drives: 2008 Base Model
Battery or starter going out?
Situation: sometimes, and only about 1 of every 15 starts does it do this whether warm or cold, when I turn the key to start the engine, instead of starting right up, the engine turns over a few times and sounds like it is trying to get going enough to start, but always starts. It always ends up starting, however, so I have never had a situation where it tried to start and wouldn't.
Concerning maintenance and mileage, my car has 100K on it, just replaced the plugs with stock iridiums, battery is about 4 years old, oil is Kendall synthetic, regular maintenance always (oil change every 5,000 miles on 95% highway miles).
Could be battery on the brink since it is 4 years old.
In the morning when it is cold, even when it is 30 degrees, I don't ever remember this being a problem and always starts right up.
I have never had a car that needed a new starter, so I am not sure if that is going out, or if I really don't have a problem. I want to get any pointers you can think of and nail this down before I do have a problem and I don't want to go to the auto shop either, but I do have a good relationship with them and they would likely check my electrical system at no charge.
Let me know if you have other questions.
Thanks for your input as always,
Pat
Yarflana is offline   Reply With Quote
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 02:15 AM
DIY: Braille Battery install texkid DIY / Maintenance / Service 39 02-19-2013 03:40 PM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 10:34 PM
Charging voltage for stock battery Vinceb DIY / Maintenance / Service 3 02-12-2011 01:10 AM
