Old 05-10-2010, 05:36 PM   #1
captainm27
Drives: 2008 Sedan A/T Silver
Had my brakes done....now handbrake is harder to pull.
So I just picked up my car from the shop. I had my front disc brakes serviced because my brakes were squealing louder than a pig seeing how bacon is prepared. But I noticed as I parked my car, the handbrake takes alot more effort to lift up. Did my mechanic tighten it for good reason? Also, what is the proper procedure for lifting the handbrake? Do you press the button and then lift, and let go? Or do you just lift, while hearing the clicking noise and let go?
captainm27 is offline   Reply With Quote
Old 05-10-2010, 05:42 PM   #2
SLIK4
Michael
SLIK4's Avatar
Drives: 07 Silver Yaris Sedan
he probably just tightened it for good measure like you said. as for how to work it i don't think either way will hurt anything but i always press the button in putting it on
SLIK4 is offline   Reply With Quote
Old 05-10-2010, 05:47 PM   #3
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Sounds like they did a good job .
I use both methods of parking brake application . Everyday I just pull and listen to the clicking sound . During "killin season" , I press the button and ease the lever up and then release the button as not to alert anything to my presence . Yes when I get to the woods the lights go off and the night vision goggles go on ...........
Old 05-10-2010, 05:50 PM   #4
captainm27
Ok, cool, thanks for your inputs. I feel better about my car now. Hee hee! Love my Yaris!!
Old 05-10-2010, 05:53 PM   #5
SLIK4
Michael
SLIK4's Avatar
yep its an awsome car
Old 05-10-2010, 05:58 PM   #6
captainm27
Awesomely Awesome!
Old 05-10-2010, 06:11 PM   #7
YarisSedan
Drives: 08 Yaris Sedan
Its harder because he did a proper brake job of not just doing the front brakes but making sure the rear brakes were cleaned and adjusted as a result your hand brake is properly adjusted. It was probally just very loose before for the longest time you have goten used to it. It should only go up about 3-4 clicks and then stop.
Old 05-10-2010, 08:00 PM   #8
captainm27
3 or 4 clicks....Got it. My hand brake was never this hard. When I bought the car, it was as loose as normal.... Glad it's good and strong now!
Rear Drum brakes bankrobber DIY / Maintenance / Service 0 04-18-2010 12:39 AM
Metal scratching from brakes alt_k1ll3r DIY / Maintenance / Service 16 02-11-2010 01:04 AM
A few questions about suspension, tires, and brakes. supmet Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-02-2009 05:55 PM
Weird question about my brakes brainless twit General Yaris / Vitz Discussion 8 01-22-2009 11:59 AM
Rotated tires and adjusted rear brakes today PICS auxmike DIY / Maintenance / Service 11 11-14-2008 09:24 AM
