![]() ![]() ![]() ![]() Drives: 2009 Meteorite 3dr Join Date: Jul 2009
What is that connector for? (in the door)
There is a white plastic connector in my doors that I noticed when I was putting in new speakers. I would say it is about 8 inches above the connector for the speakers. I would guess it is for power locks, but could also be for power mirrors or windows possibly, all of which are options I do not have.
If it is for power locks, could it possibly be as easy as buying a switch and wiring into the connector to add power locks to my current setup... So anyway, does anyone know what that connector is for?
Touchscreen DVD Navigation - 10" Bazooka Subwoofer - Kenwood Speakers - Toyota Premium Horn set AFE Pro Dry Air Filter - modified air intake box - 1ZZ-FE Throttle Body - Ultra Racing Rear Sway Bar & Front Strut Bar NST in cabin & engine bay SSK's - TWM shifter base bushings & cable bushings - Megan Racing C-Pillar Brace |
That would be connector G1 (power window master switch) or G4 (power window regulator motor). G5 is for the power door lock, and it is located by the door latch (for the actuator).
The main body ECU (which is located inside of the under dash fuse panel) controls the door locks, so you just have to add the actuators and switches to have power locks. |
Thanks CTScott. I don't plan on doing anything with it. I knew it was for some option that I don't have since it's not hooked up, so I was just wondering. I appreciate your insight.
| DIY: Replacing 2-Door Liftback Door Panel Fabric | redyaris | DIY / Maintenance / Service | 25 | 06-25-2024 01:24 AM |
| Door Handle LED DIY with pics | window_lee | DIY / Maintenance / Service | 93 | 05-31-2012 11:58 PM |
| Replaced door panel fabric with perforated leather to match Clazzio seat covers | CTScott | Cosmetic Modifications (Exterior/Interior) | 13 | 10-03-2011 11:43 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 02:47 PM |
| DIY: Changing Factory Door Handles and Lock Cover | redyaris | DIY / Maintenance / Service | 10 | 05-19-2007 05:55 PM |
