Old 05-25-2010, 02:24 AM   #1
wooverstone8
wooverstone8's Avatar
Pinkish/white stuff under the hood?
Hello all.
I was putting windshield washer fluid in my Yaris today and notice some type of pinkish/white substance on the underside of the hood. It wasn't there a couple of months ago… I looked around the engine and I couldn't see any leaks or pinkish substance anywhere, just on the underside of the hood. Sorry for the vague description, I'm not sure how else to explain it, but I can post pictures tomorrow.
Old 05-25-2010, 02:34 AM   #2
ddongbap
Mayb radiator fluid.
Old 05-25-2010, 06:30 AM   #3
swidd
Drives: Yaris HB
Some people have posted pics of a pink stripe on the underside of the hood, arising from water pump gone bad.
Old 05-25-2010, 06:57 AM   #4
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Candy Floss
Old 05-25-2010, 11:14 AM   #5
wooverstone8
[QUOTE=swidd;474705]Some people have posted pics of a pink stripe on the underside of the hood QUOTE]
That's exactly what I see on the underside of the hood. My Yaris only has 13.5k miles.
Old 05-25-2010, 10:57 AM   #6
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
START of a water pump leak. id take it to dealer for replacement.......
Old 05-25-2010, 11:18 AM   #7
http://www.yarisworld.com/forums/sho...ght=water+pump
Old 05-25-2010, 02:36 PM   #8
Hershey
wow , that's not right . We traded in a 2009 5 door liftback . Hope you get it solved .
Old 05-25-2010, 02:56 PM   #9
wooverstone8
I haven't notice any changes in performance or sound from engine and there is no check engine light. It's a very thin pink line, so I guess it must have happen just recently… How long does it take to have a water pump fix/replaced?
Old 05-25-2010, 03:22 PM   #10
BLAZINBLUEVITZ
a few hours and if your still in warranty call dealer to schedule an appt and ask for a loaner car....
Old 05-25-2010, 06:03 PM   #11
swidd
Drives: Yaris HB
So long as the red engine overheat light doesn't come on, its no worries. If it comes on, turn it off within seconds, not minutes, even if on the highway. I drove without coolant for just half a mile, and it got really hot.
Old 05-25-2010, 06:55 PM   #12
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Mine happened once, and has not happened again. It is not necessarily a busted pump, but maybe an intentional bleed by the pump because of heat/pressure?
Either way, mine is fine even after having the pink streak.
Old 05-26-2010, 04:38 PM   #13
wooverstone8
I had it check today and they said it was normal.
Old 05-26-2010, 05:28 PM   #14
bst82551
bst82551's Avatar
Drives: 2008 Flint Mica Yaris Sedan
Originally Posted by krusty View Post
The dry residue left by the water pump is not from a faulty water pump it has to do with the super long life coolant Toyota uses. It appears that the coolant can cause this condition from time to time and is considered normal.
According to krusty, it's normal. No worries, guys.
bst82551 is offline   Reply With Quote
Old 05-27-2010, 12:05 AM   #15
Hershey
KRUSTY , you can't trust that clown .
Old 05-27-2010, 12:22 AM   #16
wooverstone8
I took there word on it--but I guess time will tell. Thanks guys for all your help.
Old 06-04-2010, 03:35 PM   #17
wooverstone8
Now I'm getting an odd noise somewhere in the engine compartment and now there is more pink stuff splattered all over the underside (not just a thin pink line like last time) of the hood and in some parts of the engine. When I took to the dealership a week ago they said it’s normal and they wiped off the pink strike, but I honestly think there is something wrong now. I decided to schedule an appointment with a different dealership in another town.
Extra protection stuff? dimsum69 New YARIS Purchase Forum 9 09-19-2010 10:30 AM
C-One Replica Hood. Lets Fix this sucker! TinyGiant Cosmetic Modifications (Exterior/Interior) 56 11-10-2009 12:31 AM
Micro Image Hood Design Contest cali yaris Micro Image 209 10-04-2009 03:49 AM
Installed hood deflector, in-channel vent visors and hood seal. IsLNdbOi Cosmetic Modifications (Exterior/Interior) 16 12-20-2008 09:36 AM
Before you buy . . . check that hood! woof General Yaris / Vitz Discussion 4 12-02-2006 06:14 PM
