Old 06-19-2010, 08:05 PM   #1
jon@swoveland.com
Drives: 2007 Yaris HB
Red face Did I just fry my flasher relay?
Hi all...this is my first post to this forum, but likely wont be my last .
I just bought a small utility trailer (4'x5') to use for camping and such - already had a hitch installed for a bike rack, but I need to install a trailer wiring harness. In attempting to save some cash by doing this myself, I think I may have fried my flasher relay. Here's what happened...
On the rear-light circuit board (the board with the reverse lamp and turn indicator lamp mounted) there are what appear to be 2 male spade connector receptacles next to each of the lamps - I figured this would be perfect for wiring up the harness. To be sure these connectors were wired into the lamps, I got out my circuit tester - I first tried the spade connectors next to the reverse lamp, bingo - worked as I thought. Next I tried spade connector next to the turn signal, and this is where things went sideways...I must have been a tad careless with the tester probe tip and shorted the circuit (there was a faint spark). After that the turns signals / hazards don't work at all, no clicking from the relay, no indicators on the dash, nothin'. I've checked all the fuses, and they're all good...so the only thing I can think of is that the flasher relay itself is blown. Anybody have thoughts on this?
Thanks for reading!
Jon
jon@swoveland.com is offline   Reply With Quote
Need fog light switch and relay Jrilla DIY / Maintenance / Service 23 07-01-2011 12:12 PM
Indicator relay removal Yariscoyne DIY / Maintenance / Service 9 01-07-2011 04:42 PM
Horn Relay? MGargano DIY / Maintenance / Service 7 11-14-2009 07:01 PM
Request for help: diagramming a relay BailOut In Car Entertainment + Electronics (audio / video / alarm) 25 07-12-2009 01:59 PM
Relay Question Liu997 DIY / Maintenance / Service 8 04-25-2009 11:58 AM
