Old 06-28-2010, 09:44 PM   #1
miguelyaris07
miguelyaris07's Avatar
Drives: 2007 Nautical Blue Yaris Sedan
Electric problem! heeeelp!
greetings everyone! Im having problems with my sedan, electric ones to be specific, sometimes suddenly my radio, velocity and gas panel goes off for like two seconds and then comes on again but when it does my steering wheel gets stuck and doesnt move anywhere unless i restart the car. Its avery dangerous problem bcuz it has done that while in movement. Also i have some subwoofers that when i first installed them they damaged my HID ballasts, and since I installed the new lights i havent used the subs and the lights have worked perfectly. My mainteinance light is on too. Somebody please help
miguelyaris07 is offline   Reply With Quote
Old 06-28-2010, 10:10 PM   #2
Yikes! It sounds like your ignition is actually cutting out. When you say restart it, are you switching the key off and then back to start? If so, have you skipped going back to off and just cranked it to verify that the engine is actually not running?
Old 06-28-2010, 10:17 PM   #3
miguelyaris07
i meant restarting as in turning the car off and then on normally
Old 06-28-2010, 10:26 PM   #4
The engine is already off when you turn the key off though, right?
Old 06-28-2010, 10:51 PM   #5
miguelyaris07
nono the car is on running normal, but i cant move the steering wheel, so i have to turn the car off and then back on and then the steering wheel functions normally.
Old 06-28-2010, 11:11 PM   #6
OK. In that case, check out this thread. It sounds very similar.
http://www.yarisworld.com/forums/showthread.php?t=28729
Old 06-28-2010, 11:20 PM   #7
miguelyaris07
thanks a million man
electrical problem with car need help badly!! Adriaan DIY / Maintenance / Service 20 05-07-2010 01:40 AM
Launching @ 4Krpm problem .... need tips Parmas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 12-30-2009 09:11 PM
How can I get in touch with Toyota Regional Offices in Houston? woof DIY / Maintenance / Service 11 11-28-2009 10:29 PM
HELP!! HID problem 07yaris_fe General Yaris / Vitz Discussion 2 11-20-2006 07:00 AM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 10:12 PM
