Old 08-04-2009, 02:16 AM   #1
Cosmonaut
The Last Baron
Cosmonaut's Avatar
Drives: 09 Polar White HB
in dash clock as tach?
so i had an idea the other day.
when we upgrade the sound system clocks are standard on aftermarket HU's so the need for one in the dash is no longer necessary.
im pretty sure ive seen gadgets that display the tach in 100 rpm increments does any one know if the clock can be hacked to display the rpms?
Cosmonaut is offline   Reply With Quote
Old 08-04-2009, 02:20 AM   #2
kac
kac's Avatar
Drives: 2009 Meteorite 3dr
wow that is a neat idea, would be kool to see that done...
Old 08-04-2009, 02:37 AM   #3
tuckevalastin
tuckevalastin's Avatar
Drives: 2008 Yaris Sedan
Sodium Duck was trying to do a similar idea by cutting out the clock and placing a small tach in that area...
http://www.yarisworld.com/forums/showthread.php?t=14329
http://www.yarisworld.com/forums/showthread.php?t=11895
http://www.yarisworld.com/forums/showthread.php?t=12124
I have no idea if he ever did it though.
Old 08-04-2009, 09:17 AM   #4
Definitely doable, if you can find one of the correct size, or are willing to disassemble one to extend the wiring for the LED displays so they sit in the correct place. The clock is a separate module, so it is easily removable.
Old 08-04-2009, 03:42 PM   #5
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
why not use that LCD to show outside temp like Lt Noogie wanted to do? I would think a 3 digit tach would be weird. when at idle, your tach would read 6-8, when going balls to the way it'd say 45 or whatever.
I like the idea of using the LCD for something... maybe there is something equally as cool, but would seem more normal than a tach.
Old 08-04-2009, 03:51 PM   #6
It wouldn't have to be 3 digits. With 4 digits plus the colon for the clock there's space for a 4 digit tach.
Better yet, how about a custom module which can switch between clock, tach, temp, stored DTC's, etc?
Old 08-04-2009, 04:19 PM   #7
Cosmonaut
The Last Baron
Cosmonaut's Avatar
Tuck, i saw the threads. thats cool but to hack the clock and retain the stock finish would be much easier i think.
im sure if someone was able to hack the clock they could aslo disable the colon.
either way.
stored DTC's would be cool but wouldnt that require taping into the ecu = alot more complications i would assume.
i neither have the time or MONEY to do anything right now. im sure there has to be some electronic junkie who has tried.
meh. IF ever get to this ill post
Old 08-04-2009, 04:26 PM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
either way.
the colon is there to stay i think...
Old 08-04-2009, 04:29 PM   #9
either way.
The reason I mentioned the stored DTC's is that I have a complete working OBDII interface that a buddy and I created a few years ago (with the intention of marketing it as a $50 code reader that could also display one sensor's data {tach, water temp, etc.}). Before we finished it, the cheap readers hit the market. We completed the project for our own use and have been looking for a use for it. This thread got me thinking that a fully integrated limited function scangauge might be a perfect application for it.
Old 07-12-2010, 12:24 PM   #10
CueBall
Ruler of the free world
Drives: 09 Yaris 2D HB
Newbe here. Old post, but better than startin a new one I guess. I plan on putting a tach in my 09 HB. I like the clock hack idea. CTScott, did you figure out a way to get this info/data to display on the clock?
CueBall is offline   Reply With Quote
Old 07-12-2010, 12:27 PM   #11
Yes. I am still working on getting them to production:
http://www.yarisworld.com/forums/sho...light=yargauge
Toyota Silver Dash Kit Meteorite_Marty Cosmetic Modifications (Exterior/Interior) 72 04-13-2012 02:42 AM
Installing Speedhut tach, need help! RedRide DIY / Maintenance / Service 2 07-05-2009 05:02 PM
Setting the clock after DST change ToddR DIY / Maintenance / Service 10 03-10-2009 12:33 AM
How to install tach? charles nelson DIY / Maintenance / Service 1 08-04-2007 12:34 PM
Auto-Meter Silver Sport Comp Mini Tach ChinoCharles In Car Entertainment + Electronics (audio / video / alarm) 7 02-26-2007 06:14 PM
