Old 07-19-2010, 08:05 PM   #1
walt101786
Drives: 07 Toyota Yaris Hatch-Back
K&N Fliter drop in and looking for more mod
Well, recently i had upgrade my ride a bit, which i had put K&N Filter drop in for my 07 Yaris Hatch-Back...well as for now, i am thinking of putting on an exhaust....which by the way i'm thinking of weilding on an after-market exhaust...any suggestions with this mod? and for future mod, what else should i do
walt101786 is offline   Reply With Quote
Old 07-21-2010, 08:44 AM   #2
anexrx7
Drives: 08 MM HB
Don't do it your self unless you're an expert. Otherwise you will have it too loud, makes noises when you don't want it and you'll spend more money trying to fix and change it. Look at Micro Image for some ideas or even a full exhaust from them. Just so you know, theres very little you can do to actually improve "performance". The tuning, which you'll have to get a fuel controller to fix, is the down fall for any improvement. Just keep that in mind.
I did notice a large change in MPG after changing the stock air filter though.
anexrx7 is offline   Reply With Quote
Old 07-31-2010, 08:02 PM   #3
2007tRD
CERTIFIED ASE/SUBARU TECH
2007tRD's Avatar
Drives: 2007 VIOS S
Is this implying a fuel controller can be a performace inhancing addition to an engine with a K&N drop-in and an exaust?We know the 1/2NZ-FE's run rich from the factory.
2007tRD is offline   Reply With Quote
Old 07-31-2010, 08:41 PM   #4
Right. A fuel controller could be tuned to lean the mixture and make more power.
Old 07-31-2010, 08:51 PM   #5
2007tRD
2007tRD's Avatar
Drives: 2007 VIOS S
What brand do you recomend? I also heard modifying the stock airbox unlocks some pony's, is that true...or is that a wives tale?
Old 07-31-2010, 09:34 PM   #6
anything that allows the car to breathe better will create some power. (Especially since it tends to want to run rich). Short ram / opening the airbox up / cold air intake / larger throttle body -- all help do the same thing.
As for fuel controllers, CamCon, eManage and AEM FIC have all been used successfully to tune the Yaris.
Old 07-31-2010, 10:50 PM   #7
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
Drives: 2008 Yaris LB
URD makes a MAF Sensor Calibrator that works great for controlling fuel.
http://www.urdusa.com/product_info.p..._id=1260198051
_________________________________________________
Nitto Axle-Back--Tanabe DF210s--UR 23mm Rear Sway Bar--Penguin Garage 10mm Hub Spacers
Jeemee is offline   Reply With Quote
Old 08-01-2010, 12:04 AM   #8
2007tRD
2007tRD's Avatar
Drives: 2007 VIOS S
Well as you guys know, im a subaru tech.The subarus have 3 different injector pulse widths,30%-50%-100%.These durations are specific for idle,cruise,and wide open throttle.The point im getting at here is:The yari are known to have a "rich" fuel mixture,is this information drawn from dyno results...durring WOT?
