Old 01-21-2010, 07:22 AM   #1
bear4
Drives: 2007 yaris
engine temp
I have a question for members running the Scan Gauge - what is you normal engine operating temperature in city/highway driving? Mine seems to fluctuate by 3-4 degrees in the city - it goes up on acceleration and goes down on idle, and normally stays around 86-88 C. Was wondering if this is normal. It stays 85-86 C on the highway.
Thanks!
bear4 is offline   Reply With Quote
Old 01-21-2010, 12:22 PM   #2
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
A variation of +/- 5 degrees is perfectly normal. You're talking about maintaining the temperature of about 2 gallons of water that's seeing a wildly varying set of circumstances. The engine makes more heat when you accelerate, and the cooling system doesn't act (by turning on the cooling fan) on that until it senses that there has been a change, and that the change is enough to bother acting on. (you wouldn't want you fan to cycle on and off and on and off constantly while you were idling, right?)
Wanna see something freaky, try watching the temp closely on a cool morning as you're driving "briskly" through the initial warm-up. (not abusive, just enough to get the car to warm up quickly) You'll often see the point at which the thermostat opens. The temp will rise up to a certain point, then the thermostat will open and allow a rush of cool water from the radiator in and the temp will drop significantly. Then it will warm back up again and stabilize.
Old 01-21-2010, 12:42 PM   #3
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
186Fis where mine usually hovers at. in colder (sub 30's) weather sometimes it'll dip down to 182 easily. in the summer months when temps are in the 80's and up it will often peak over 190. only once did it go over 200.
Old 01-21-2010, 12:57 PM   #4
Woody_Woodchuck
Drives: 2008 Yaris LB 5M
X2, same numbers on my SGII
Lifetime log
Woody_Woodchuck is offline   Reply With Quote
Old 01-21-2010, 06:11 PM   #5
SilverGlow
Drives: 2007 Yaris Hatchback
My 2007 LB is mostly at 181F. During the summer months it is mostly around 188F. When the day is around 30F it is in the high 170s.
SilverGlow is offline   Reply With Quote
Old 01-21-2010, 06:11 PM   #6
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
I think I read in the service manual that's linked online here that nominally the thermostat opens at 184 F, and the fan turns on at 204 F. When you're moving, the air blowing in the grille is plenty to keep the radiator cooled under most circumstances. The fan mostly runs when you're idling or moving slowly in heavy traffic. Or whenever the air conditioning compressor is on.
Old 01-21-2010, 08:22 PM   #7
BuildCode
BuildCode's Avatar
Drives: Black 5-Spd Sedan S
Another me too post. Mine runs between 182 and 186 F. I have not owned the Yaris during much hot weather yet, but when it was warm around here I have seen it above 200 F in traffic :)
BuildCode is offline   Reply With Quote
Old 01-22-2010, 12:45 AM   #8
Wita09
Drives: 09 Yaris Hatchback
My SG reads 181 to 186.
Wita09 is offline   Reply With Quote
Old 07-30-2010, 12:35 AM   #9
Hard_Yaris
Drives: 07 Yaris
Wow i had no idea the fan kicked in @ 204 F or 95.5 C.
i kinda thought my fan was not working.
today the Yaris temp got up to 90 C or 194 F
When I owned my Echo, the fan used to turn on all the time. This was before I had a ScanGuage2.
Do you think the Fan Sensor temp was set lower on the Echo?
What Temperature Does your Ride run @?
Hard_Yaris is offline   Reply With Quote
Old 07-30-2010, 03:31 PM   #10
auxmike
auxmike's Avatar
186F during normal driving.
Fan kicks on at 202F.
Green "warm up" light turns off 131F.
Old 07-30-2010, 03:32 PM   #11
auxmike
auxmike's Avatar
Yaris fan runs all the time when the A/C is turned on.
Old 08-02-2010, 11:45 AM   #12
Hard_Yaris
Drives: 07 Yaris
Ahh... I have no A/C.
Old 08-02-2010, 05:55 PM   #13
Hard_Yaris
Drives: 07 Yaris
The weather has been very hot here, but when we catch a breeze its got a coolness to it.
so most of the Air getting swallowed by the intake never reaches over 40 C or 104 F according to the Scan Guage II.
The Nitrous Thread ChinoCharles Performance Modifications 116 02-16-2016 04:07 PM
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 06:34 AM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 05:22 AM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 08:11 PM
Turbo Charged Normal Engine Temp. Over40 Forced Induction Forum 9 03-01-2009 02:27 AM
