Old 07-31-2010, 08:53 PM   #1
Bladerunner
Drives: Toyota Blade
More cruise control
Hi all
I have read all I can find about installing cruise control but nowhere have I been able to find any info on installing extra pins on the clock spring. Let me explain. The car has all that is required for the install e.g. dash light, hole in side of steering wheel. The problem is, there is a plug hole next to the airbag plug on the clock spring but it doesn't have the two pins required for the switch to connect to. My question is, is it possible to install the two pins? I know I can get the pins from Toyota as "spiral connector repair terminal 82998 12870.
Bladerunner is offline   Reply With Quote
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 10:22 AM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
OEM Steering wheel with cruise control? suckerface Cosmetic Modifications (Exterior/Interior) 9 07-25-2010 09:40 PM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 07:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 04:55 PM
