Old 08-15-2018, 03:54 PM   #1
komichal
Iridium spark plug - longer thread
Hi guys,
so far I have been using "normal" NGK BKR5EYA but I wanted to try some Iridium plugs. Local store recommended me Denso IKH16TT.
Now I am comparing them against each other and the Denso has considerably longer thread part... the rest ("above the nut") seems identical. Check the picture...
I must say I did not have the balls to put the longer plug in. Any experience with it please? Do I need to ask Denso directly to be 100 per cent sure?
My Yaris 2007 uses 2SZFE engine - 1.3 with 64kW.
Thank you!
Spark plugs suggestion walt101786 DIY / Maintenance / Service 29 03-05-2023 10:06 PM
NGK 5464 Iridium IX vs NGK 4996 Laser Iridium Spark Plugs Cigar_Maverick DIY / Maintenance / Service 8 05-21-2016 05:07 PM
Iridium spark plugs? Septembersrain Third Gen Yaris General Discussion 4 07-02-2014 11:56 AM
bit of spark plug insulation may have fallen into cylinder alagappan the proud DIY / Maintenance / Service 20 01-09-2014 07:10 PM
bought iridium spark plugs but need help Shinare DIY / Maintenance / Service 24 08-05-2013 01:21 AM
