Old 09-06-2010, 12:18 PM   #1
1.5ty
Rollerskate
1.5ty's Avatar
Drives: 09 hb
turbo feed lines
where is the best place to tap a oil feed line on a 09 yaris
1.5ty is offline   Reply With Quote
Old 09-06-2010, 01:34 PM   #2
one good place is where the pressure sensor is.
Old 09-06-2010, 04:30 PM   #3
Focus_Sh1ft
Focus_Sh1ft's Avatar
http://www.glowshiftdirect.com/oilfi...-34unf-16.aspx
Should be more than it's worth. HIGHLY recommended.
Old 09-06-2010, 06:47 PM   #4
1.5ty
Rollerskate
1.5ty's Avatar
Drives: 09 hb
thanks for the help
Old 09-06-2010, 06:50 PM   #5
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
I tapped at the pressure sensor. My oil feed line came with a T-fitting to mount the sensor and line.
pimp my yaris is offline   Reply With Quote
Old 09-06-2010, 09:54 PM   #6
1.5ty
Rollerskate
1.5ty's Avatar
Drives: 09 hb
i know this is a dumb ? but where can i find the oil sensor Ive looked all over the engine bay and didn't come across it
Old 09-06-2010, 10:02 PM   #7
sleey0
Drives: 2008 Yaris LB
Can that be used as a drain/return line as well?
sleey0 is offline   Reply With Quote
Old 09-06-2010, 10:10 PM   #8
Focus_Sh1ft
Haha, I asked the same thing originally. No, it can't be because the oil filter is pressurized. It can only be used as a feed (that means it can be used for oil pressure readings as well).
Yeah, it's stupidly difficult to get at. It's right by the starter, and directly under the intake manifold. I'm pretty sure you'd have to take the manifold off, because I couldn't even get at it from the bottom.
Old 09-06-2010, 11:03 PM   #9
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
It's so easy to get at from the bottom. Just take the starter off. It's two 14mm bolts.
Old 09-06-2010, 11:41 PM   #10
pimp my yaris
C'est la vie
If U removed the front bumper cover witch is pretty easy and then U removed the plastic shroud that is to the left of the radiator [two plastic clips hold it in]. You will be able to get it from the front very easily. Wide open working conditions. If your installing a intercooler U will need to remove the bumper cover anyway. You will need a 24mm deep well socket to remove the sensor.
Old 09-06-2010, 11:41 PM   #11
1.5ty
Rollerskate
1.5ty's Avatar
Drives: 09 hb
thanks again guy right now i have a turbo kit on the was ill let yall know how its going
FS: 2005 Scion xA RS2.0 Turbo uberegg Cars for Sale by private party 40 04-03-2010 12:45 PM
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 11:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 12:59 PM
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 01:30 PM
delayed turbo project... joey1320 Forced Induction Forum 8 09-27-2007 12:18 AM
