Yaris323
Drives: 09 Sedan Yaris 06 Ford Mustang Join Date: Mar 2009
TRUE OR FALSE ???
Is it true that the sedan gets more MPG then the HB ??
Also does a HB weigh more then the Sedan ?? |
No, I think the HB is lighter. The back end creates more drag, but the weight savings offset it. The sedan is 4 inch longer wheelbase and 16 inches overall longer, but only 35 pounds heavier+/-. The ride is better in the sedan too. Depends what your looking for. I get right around 40mpg with a 2010 sedan.
#3 | |
Yaris323
LB / AT 2335 lbs Sedan / MT 2288 lbs Sedan / AT 2321 lbs looks like the HB Weighs more. ( found this info. on the forum) That must mean the sedan gets better MPG. |
Only Happy When it Rains
i don't think that little of a weight difference will make much of a difference on gas mileage. More important will be the driver.
Colin Chapman disciple |
![]() ![]() ![]() Drives: 07 Sedan - 5 Speed Manual Join Date: May 2006
Page 3 on this PDF from toyota gives the specs of the 2011's.
Weights and mileage estimates pretty much look like this: 3-Door Liftback – Manual 2311 lbs 29/36 3-Door Liftback – Auto 2355 lbs 29/35 5-Door Liftback – Manual 2320 lbs 29/36 5-Door Liftback – Auto 2364 lbs 29/35 Sedan – Manual 2313 lbs 29/36 Sedan – Auto 2346 lbs 29/35 |
The Fit is NO!
Drives: '09 3DR "S"|'87 Caddy Brougham Join Date: Dec 2008
Diffusers might help the LB a little bit. I am surprised by those weight figures, you would think 2 extra doors plus the extra length would make the sedan a little heavier rather than a little lighter than the 3 door. In reading the specs I am also surprised to see the 5 door only weighs like 9 pounds more. I would think adding all those extra hinges and locks and window mechanisms would add more than that. Also, I think those weights are for the base models with no power anything, I wonder how power equipment would effect those figures.
My OTHER car ![]() Please ignore the Ferrari
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
I don't have the spec sheet any more from 2008 when I bought. The HB is taller (I like the head room) which could create more wind resistance.
Making a decision without following it with an action is still a fantasy. |
| NST TRUE Racing Tow Hooks | NonStopTuning | NonStopTuning | 59 | 01-06-2010 01:45 AM |
| True or False? New USA Dollars | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 34 | 08-31-2009 08:49 PM |
| True of False.. a dealership in the US can order you a Yaris | xed | New YARIS Purchase Forum | 16 | 09-21-2007 12:28 PM |
| the stories are true | sanchez | General Yaris / Vitz Discussion | 2 | 11-07-2006 08:17 AM |
| True differences. | Boonespeed | General Yaris / Vitz Discussion | 7 | 06-26-2006 08:51 PM |
