![]() Drives: green 2007 yaris Join Date: Jun 2010
Need an AC expert
Ok, so here's my problem, I have a 2007 sedan and my ac will not start cooling for about 15 minutes after I start my car. After that, it cools fine. The compressor is not running during that time. The blower blows warm air, and then it just starts blowing cold air. Anyone have this problem?
Considering that you have an 07, do you ever see your alternator light flickering?
The AC Amplifier (which is the ECU for the A/C) controls the cycling of the compressor. There are many reasons why it would not turn on the compressor (including things like refrigerant volume or pressure issues), but the AC amplifier also gets a signal from the alternator that tells it that the alternator is running. This prevents the AC amplifier from running the compressor when it will kill the battery. There is a common problem with 07s (and a TSB for it) with the voltage regulator within the alternator becoming corroded. |
Thank You very much for you help.
![]() ![]() ![]() Drives: '08 Blazing Blue Yaris LB Join Date: Sep 2009
Glad I got an '08
| Photoshop expert, Pls Help!! Anyone? | evo165 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 07-19-2010 07:44 PM |
| Geek or Computer Expert help me out? | jamal1984 | Off-topic / Other Cars / Everything else Discussions | 5 | 03-23-2010 10:37 AM |
| Computer Expert Help | jamal1984 | Off-topic / Other Cars / Everything else Discussions | 6 | 11-26-2008 10:33 PM |
| This Question is for Digital Camera Expert ! | jamal1984 | Off-topic / Other Cars / Everything else Discussions | 20 | 07-18-2007 01:00 PM |
