Old 06-29-2010, 11:14 AM   #1
evo165
evo165's Avatar
Drives: peArL yAvItZ!!
Send a message via MSN to evo165
All Thai Yaris with NST pulley, pls read...
Hi to all, can anyone Thai made Yaris mount on the water pump & alternator pulley without any problem? Are they the SAME OEM side pulley? All Thai Yaris with this mod, PLEASE advise & confirm...
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres
evo165 is offline   Reply With Quote
Old 06-29-2010, 12:46 PM   #2
One of the three pulleys requires a shim, I believe it is the water pump.
[edit] it's the alternator pulley, see below
Old 06-29-2010, 02:18 PM   #3
Red Horse
Red Horse's Avatar
Drives: 2008 Yaris sedan A/T
A shim on water pump? Do we need that on usmd yaris
Red Horse is offline   Reply With Quote
Old 06-29-2010, 02:39 PM   #4
it is the alternator pulley, the design is a little bit different, you can install it, but you need to put in a spacer to align it properly. you should contact the member MANSETH here, he has done it.
Old 06-29-2010, 02:39 PM   #5
nothing needed on USDM cars.
Old 06-29-2010, 10:37 PM   #6
evo165
evo165's Avatar
Thanks to all who reply. Bro eTiMaGo, i remember reading up your old post that the alternator pulley doesn't fit into our thai yaris. But do you still mount it with additional spacer as mentioned? thank you.
Old 06-30-2010, 02:48 AM   #7
Schizoprenia
Drives: Toyota Yaris 1.5 M/T '06
hello, i just wanna share my experience..
i bought my pulley from a supporting vendor here, MICRO IMAGE, after i scour the forums i decided to put up only the 2, underdriven crank + water pump. so alternator pulley not changed. works fine for me, and i believe a change in the alternator pulley doesnt generate much/any power one can feel... if not for the viewing pleasure...
mine's a thai built yaris in indonesia. hope it helps.
Schizoprenia is offline   Reply With Quote
Old 06-30-2010, 03:16 AM   #8
evo165
evo165's Avatar
Thanks Schizoprenia for sharing. I pm MANSETH regarding this. He managed to put on all 3 pulleys at one go. Only the alternator pulley require some shim/spacer to alight the belt.
Since you have the alternator pulley, why not try it with some shim/spacer?
Old 07-03-2010, 10:52 AM   #9
moh
moh's Avatar
Drives: Yaris Sedan
I have thai built Vios, I just bought NST underdrive set (Crank, WP, Alt) from MI last week, and still in shipping ..
what kind of shim/spacer should i use, so all pulleys can be installed?
maybe anyone have pictures?
Thanks,
|Blitz S/C|aFe Intake|NST SSK|NST Busing kit|Ralco Short Shifter|Dastek Unichip type Q|Dastek Throttle Control|1ZZ Injectors|1ZZ TB|Custom Header|Custom Exhaust|Head Porting|Momo Drifting Steering wheel|Momo shiftknob|Denso Irridium Sparks|Buddy Club P1 Racing Wheels|195/50/R15|Tanabe NF Coilover|Goodrich SS brake lines|Ultra Racing Front Strutbar|NRG Grounding kit|Custom Grill|Custom Eyelid|Rear Sway bar|
moh is offline   Reply With Quote
Old 07-07-2010, 12:08 AM   #10
MANSETH
KAVINT
Drives: KAVINT
Guys,
Sorry, for late pictures. I spend sometime to find the NST because I already put on the supercharger.
This is Metal lathe. The reason I use metal because I experienced aluminum slip.
For thickness, I suggest you guys to measure the differences of the stock one and NST in order to get the straight between alternator and water pump.
By kavintyaris at 2010-07-06
MANSETH is offline   Reply With Quote
Old 08-15-2010, 07:11 AM   #11
Vanquisher
Vanquisher's Avatar
Drives: 2007 Vios
Shouldn't be a problem fir vios in singapore den cos it's thailand made.
Shall order thru MI soon
Vanquisher is offline   Reply With Quote
FS: NST 10% Underdrive Crank Pulley hatchbackkid82 Items for Sale by private party 11 02-26-2010 09:22 AM
Hmmmm noticed substantial mpg increase with nst pulley... YarisSedan Performance Modifications 11 04-16-2009 05:42 PM
