Old 04-28-2009, 11:50 AM   #1
Lazerdot
Lazerdot's Avatar
Drives: Blazing Blue 08 liftback
Spring Stiffeners
I have TRD springs and shocks and have heard that I can stiffen the rear end with rubber inserts into the coil off the rear springs. If true were might I find these gadgets? Garm, any ideas? I could use a bit less push at the autocrosses.
Lazerdot is offline   Reply With Quote
Old 04-28-2009, 11:51 AM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
i don't sugggest them ..
Originally Posted by xnamerxx
you nailed it sir.
Old 04-28-2009, 11:54 AM   #3
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
I wouldn't use them either. Springs were not designed to work with bits of rubber stuck between coils.
Old 04-28-2009, 12:26 PM   #4
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
I've used them. Had them on my wife's Saturn, all four corners, for at least 6 years. No problems. (same car also had half a coil cut off of each spring...)
Like anything else, you need to understand what you're doing. Adding a rubber spacer between the coils of a spring effectively removes that spring from the picture when the rubber is compressed. If you look up the formula to calculate spring rate, number of coils is a major factor, so removing a coil will raise the spring rate.
The rubber blocks also will raise ride height, so be aware of that.
The cool thing about them is that they're super-easy to install and remove. If they have the desired effect, great! If not, yank 'em back out.
You can get coil spring spacers from JC Whitney, among other places.
Old 04-28-2009, 12:28 PM   #5
^ there you go -- JC Whitney. I used to shop in their catalog for my first car, a 1962 Karmann Ghia (sigh).
Old 04-28-2009, 12:30 PM   #6
kngrsll
Apexing Egg!!
kngrsll's Avatar
This is an article on spring rubbers:
http://www.longacreracing.com/articles/art.asp?ARTID=31
And these are some for sale:
http://www.google.com/products?q=lon...num=1&ct=title
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 04-28-2009, 01:03 PM   #7
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
You could also increase air pressures in your rear tires so that they don't grip as well as the fronts (or lower the fronts).
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 04-28-2009, 02:11 PM   #8
kngrsll
Apexing Egg!!
kngrsll's Avatar
great great point
Old 04-28-2009, 02:20 PM   #9
schleppy
I love momentum.
schleppy's Avatar
+10 on tire pressures. I'd play with those before I started putting rubber bits in the spring coils.
Old 04-28-2009, 02:33 PM   #10
Loren
What?
Loren's Avatar
Guys, don't let your prejudice of the unknown cloud your vision. There's nothing wrong with using spring spacers, they're just another way to change spring rate. Most aftermarket spring kits are designed to understeer, just like the stock suspension is designed to understeer. Understeer is safer for the average idiot, it's predictable.
Putting spring spacers in the rear will allow you to put a little more spring rate back there, which is a good thing. Raising the tire pressure will have a similar end effect, but not exactly the same.
Raising the rear tire pressure raises the effective spring rate of the tire, but the suspension is so soft that it doesn't make much difference. Mostly what you're doing (if you add enough pressure to do it) is crowning the rear tire treads and causing them to lose grip. This will allow you to oversteer, but it does NOT improve the front grip. Raising the rear spring rate (just like adding a rear swaybar) transfers weight to the front and allows the front tires to grip more while also making the car more prone to oversteer.
So, while tire pressures can be helpful to play with, they're not going to do as much as spring rates will.
Old 04-28-2009, 03:30 PM   #11
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
Wow, like Loren stated, i also see no problems adding rubber inserts to springs. Every aftermarket set i have ever used on my cars (besides the yaris) have had them already installed. I guess on heavier cars they are more needed on the lower coils?
It's not what you drive, or how much $$ you throw at the car. Mod the ballast on the front left first!
anonymous user is offline   Reply With Quote
Old 04-28-2009, 04:40 PM   #12
fuji
fuji's Avatar
Drives: Polar White Yaris HB
They aound like a good way to further tune your spring rates and in some cases weird guys like myself who enjoy close to stock ride heights!
fuji is offline   Reply With Quote
Old 04-28-2009, 07:26 PM   #13
Lazerdot
Lazerdot's Avatar
Thanks for all the input everyone.
I'm on Kumo MX Tires now and the fronts tend to "roll over" when I run them at less then 40PSI. I was told it looked as if the rims were almost on the ground. So, I have done the tire pressure thing in the back, but 50psi is max recommended.
The wiggle room is getting narrow. Driver skill is even narrower, so the spring stiffiners seemed like a neat idea as they may be cheap, removable and great as a temporary fix.
My TRD sway bar is 19mm, the other brand is 24mm?, I think. Till I get that this might be the best fix.
I know another tire/wheel combo will help as well. But, guns and ammo first, so far they aren't trying to ban AutoCross...
Old 04-28-2009, 07:28 PM   #14
Loren
What?
Loren's Avatar
I'd put the fronts up to 45 or more if they need it to keep from rolling over. Don't forget about alignment. Sounds like you could use some more negative camber in the front.
Old 04-28-2009, 09:09 PM   #15
Lazerdot
Lazerdot's Avatar
Camber may be a help. Garm has some camber "screws" ? available but I don't know how they work. The car has been aligned but very short on negative camber. I used 45psi and around 50in the back. Not bad, but still pushes. I was a bit fast on turn entry which would create the need to loosen the rear a bit. Maybe I should slow down a bit too...?
Thanks for the info and suggestions.
Old 04-28-2009, 09:47 PM   #16
Loren
What?
Loren's Avatar
Yes, "slow in, fast out" is the quickest way through any turn. Overcook the entry and you'll understeer and lose even more speed in addition to losing your line.
Camber bolts are an option, or just take a die grinder to the lower strut bolt holes.
Old 04-28-2009, 10:42 PM   #17
SailDesign
Drives: .
I hear that "sigh". My first car in the States was a 72 Ghia. Lotsa JC Shitney parts in it.
Old 04-28-2009, 10:54 PM   #18
yarstar
Drives: 2008 Absolute Red HB
I gotta set of spring rubbers I ran on my TRD springs for a year to keep the 17"s from rubbing. I'm on 15's w/ coilovers now. If you want my spring rubbers, PM me and I'll send you a pic. I think I paid $50 for the pair so $25 shipped is cool. They really stiffened the ride too.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
ideal spring rates for coil-overs on Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 30 01-27-2009 05:24 PM
H&R spring for yaris Nas155 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-23-2008 09:44 PM
glowshift gauges combo, DF tanabe spring, + leather boot for sale cdmyaris Items for Sale by private party 19 09-28-2007 04:33 AM
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 10:26 PM
Save up to $40 - TWM Spring Sale! TWM Performance Sponsors Classifieds Area 0 04-03-2007 04:04 PM
