Old 10-18-2010, 09:09 PM   #1
Siffleu
Siffleu's Avatar
Drives: Yaris 2006
alternator bushing JAMMED !
here is a sample found on the forum
I am talking about the "nut bushing" found on the left part of the picture (the bushing that move on the 14mm bolt)
the head of that bushing is ~19mm and jammed into the "frame cast" of the alternator
I cannot screw the 14mm bolt correctly to let the alternator in place securely
the bushing head is not fit correctly into the casting, in fact the "summit" 2 pan of 6 pan head is jammed into the casting
I did removed the alternator
I've try to screw the bolt and hit on it to let the bushing moving out.. no sucess
I've try a 19mm spanner and hit on it to bring it back to original position, no sucesss
this is soaked in loose nut for 3 days now...
I'm out of ressource
heating is not a good idea
hitting more is not a good idea
anyone can help ?
thanks
Siffleu is offline   Reply With Quote
Old 10-18-2010, 09:22 PM   #2
That "bushing" isn't removable. Just the shoulder bolt that goes through it is removable.
Old 10-18-2010, 09:46 PM   #3
Siffleu
Siffleu's Avatar
Drives: Yaris 2006
since it is "turn in" in it seat... what should I do ?
Old 10-18-2010, 10:59 PM   #4
Were you able to get the bolt out?
Old 10-20-2010, 08:04 PM   #5
Siffleu
Siffleu's Avatar
Drives: Yaris 2006
main 14mm bolt ajustment is hard
last meccanic tried too much to adjust the alternator..this is the reason why the bushing is "turn in" inside the casting
no I am unable to remove bushing or make it move
I really need help !
Old 10-20-2010, 08:37 PM   #6
OK - I was thoroughly confused until I just took a look to refresh my memory. That part is not designed to be replaced. I think I would either drill it out, or cut it out and then just use a longer bolt with a washer and a lock nut.
Old 10-20-2010, 10:11 PM   #7
Black Yaris
der Zeck
Black Yaris's Avatar
if it came off like that, you should not modify it to reinstall.
if this is the same part you took off your car and you are trying to reinstall it..... YOU are doing something wrong
Many times you have to align the alternator PERFECTLY onto the bracket, and wiggle it a little at a time till the bolt holes line up
Old 10-20-2010, 10:24 PM   #8
The bushing type piece is a separate piece that can wiggle, but should not rotate. In his case, it broke loose when trying to loosen the alternator, so now he can't tighten the bottom bolt.
Old 10-21-2010, 11:52 AM   #9
Siffleu
Siffleu's Avatar
Drives: Yaris 2006
if it's separated parts, can I remove it ?
somebody replied it can't be removed
right now, it now turning itself into the cast it HAS turn in, so now it's jammed in a way it can't act a moving bushing...
Old 10-21-2010, 11:59 AM   #10
If its is jammed, and not freely rotating, then you should be OK. It just has the bit of wiggle to help with getting the bolt lined up.
Old 10-22-2010, 11:12 AM   #11
Siffleu
Siffleu's Avatar
Drives: Yaris 2006
problem solved !
I've treated with a chemical that remove rust and soaked that part, add somes oil and a bolt + impact tool on the bolt et voilą !!
Driver door won't open, jammed cable? Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 13 02-24-2011 02:14 PM
