Old 12-19-2006, 04:48 AM   #1
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Angry Problem with Gearbox?
Hey guys.
Yesterday I noticed something ackward in my Yaris.When I am choosing 1st/2nd gear, I feel some vibrations from the stick, like it is scratching the inner walls of the transmission.Maybe it needs some oiling.I have manual transmission.
I will install my short shifter(when it arrives) to see if the problem comes from the OEM stick.It's pretty annoying!
Old 12-19-2006, 05:50 PM   #2
Katana
Katana's Avatar
Any ideas guys?
Old 12-19-2006, 06:20 PM   #3
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
Sorry I never had that problem... But I did install the Short Shifter at 500 miles
Nutzoids is offline   Reply With Quote
Old 12-19-2006, 06:27 PM   #4
acrbill
Drives: Polar White Hatch
before you install the shifter, take it to the dealer. Perhaps something is wrong that they need to fix. If you go in there with a short shifter they will say it caused the problem.
http://home.comcast.net/~job0b/ywsig.gif
ChinoCharles Intake supporter.
acrbill is offline   Reply With Quote
Old 12-20-2006, 04:45 AM   #5
Katana
Katana's Avatar
Yes I am planning to do that.Thanks guys.It is really an unusual problem!
Old 12-20-2006, 08:48 AM   #6
Katana
Katana's Avatar
Today the problem is not as intense as yesterday.
Maybe my Yaris wants to persuade me not to be doing street racing!
Old 12-22-2006, 04:47 AM   #7
El Jefe
Drives: 07 yaris s sedan
to me it sounds like the cables of the shifter need to be lubed, toyotas use 2 cables to shift gears, when those become dry they can make some weird noises, just take it in to the dealer if you can and show them
El Jefe is offline   Reply With Quote
Old 12-23-2006, 08:20 PM   #8
Pars
What causes the shift cable to become dry? And is if difficult to lubricate it yourself?
Pars is offline   Reply With Quote
Old 12-22-2006, 08:11 AM   #9
Katana
Katana's Avatar
I did it myself today, before reading your post, and it is ok.
Thanks anyway!
Old 12-22-2006, 11:18 AM   #10
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
the only thing I've noticed is that it's always somehow hard to engage the 1st gear as long as the car it's not completely immobilized
hystria is offline   Reply With Quote
Old 12-22-2006, 12:22 PM   #11
acrbill
Some cars are worse than others. I think it has to do with the syncros trying to match the speed between shifts and since 1st gears ratio is 3.545 and 2nd is 1.904 there is a lot of speed to change.
Once you are moving there really is no reason to go back into first.
Old 12-23-2006, 12:32 PM   #12
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
what about when you're racing?
Old 12-23-2006, 02:16 PM   #13
acrbill
Then there really is no reason for it. Most of the time you try and shift as seldom as possible.
Old 12-22-2006, 02:08 PM   #14
Katana
Katana's Avatar
Well sometimes it is hard to engage 1st gear even if you have less than 5km/h.
Old 12-22-2006, 03:27 PM   #15
acrbill
You still should never go back into 1st even at 5kp/h. If you still feel an overwhelming need to do so try putting the shifter back to 2nd to speed up the syncros then go into 1st.
There is nothing wrong with the transmission.
Old 12-22-2006, 07:15 PM   #16
hystria
hystria's Avatar
Here's a STOP at every street corner. Two choices: completely stop the car and make the rear car going to flash you, or trying to slow the most and then restart - there's the trouble because is hard to restart in the 2nd gear so I had to put it in the 1st while still moving.
Old 12-22-2006, 03:12 PM   #17
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
if you're rolling slowly, blip the gas with the clutch in, and it will make it easier to put it back in 1st.
2006 Red Blitzed RS 5-door
Old 12-22-2006, 04:44 PM   #18
Katana
Katana's Avatar
Of course I am never doing it, but I what I want to say is that in Yaris, the 1st gear should only be engaged if the car has come to a halt.
Gas pedal problem? Befuddled Performance Modifications 28 01-27-2010 10:55 AM
HELP!! HID problem 07yaris_fe General Yaris / Vitz Discussion 2 11-20-2006 07:00 AM
Rear shock absorbers problem Yaris PTY-507 Central and South America 1 10-16-2006 05:07 PM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 10:12 PM
no tach= problem for newb? BrownNBubbly General Yaris / Vitz Discussion 19 05-18-2006 03:16 PM
