Old 07-30-2009, 10:40 AM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
metal snapping sound on front end when braking...
did anyone encountered a metal snapping sound on front end when braking.or slowly going on speed bumps.....it doesnt happen all the time but that sound is annoying..
Old 07-30-2009, 12:05 PM   #2
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
ive heard a sound like that when my brake pad caliper clip fell out.
mikenacarato is offline   Reply With Quote
Old 07-30-2009, 12:38 PM   #3
cdavidhess
cdavidhess's Avatar
Drives: 2008 White Yaris Sedan 5 speed
I was getting a loud clicking or clunking sound sometimes when braking. This was right after the dealer did some brake service at 15,000 miles.
When I took it back to the dealer and complained about the noise, they replaced the rotors. Problem fixed. I don't know whether replacing the rotors actually fixed the noise or that they just got the brakes put back together right.
cdavidhess is offline   Reply With Quote
Old 07-30-2009, 01:00 PM   #4
marcus
toyota
marcus's Avatar
its more like metal snapping out of place..weird..
Old 07-30-2009, 03:01 PM   #5
Brian
Brian's Avatar
Could it be caliper knockback?
Old 07-30-2009, 04:44 PM   #6
marcus
toyota
marcus's Avatar
knockback..dont know what that means
Old 07-31-2009, 07:11 AM   #7
SeaYa
Is about to 'SeaYa' later
SeaYa's Avatar
Drives: 08 MT Sedan
Assume your wheels lugs are nice and tight?
His grace is sufficient.
SeaYa is offline   Reply With Quote
Old 07-31-2009, 08:41 AM   #8
Forrest
Drives: 08 LB BLACK
Take it back to dealer...make them fix it.
Forrest is offline   Reply With Quote
Old 07-31-2009, 11:02 AM   #9
marcus
toyota
marcus's Avatar
good idea forgot about the lugz...it could be it ill. check thanks.
Old 07-31-2009, 03:00 PM   #10
highwaypass
Captain Slow
Drives: '08 1.5 hatchback
mine was. It did disappeared on 10k service but then came again just three days after the service.I went back again,but they said nothing wrong,so they just cleaning out my brake,then it disappeared again.Just another a week,it comes again.Until now.
There's only 1 brand,2 drive,3 words,4 you: TO-YO-TA
highwaypass is offline   Reply With Quote
Old 08-03-2009, 07:51 PM   #11
trini_per4mance
trini_per4mance's Avatar
Drives: 2007 Toyota Yaris S Sedan
Yes, I have. It's actually the ABS doing that. You only hear it when you are braking and the front tires are at a points where they slip or skid. Just goes to show how good the ABS on the Yaris are. By hearing it, at least you know it's working.
Yaris 500,000 miles in 6 years 9 months 3 weeks and 3 days and still going strong!!!
http://www.youtube.com/watch?v=YnTlNLz9Iqc
http://money.cnn.com/galleries/2010/...le_cars/5.html
http://www.subcompactculture.com/200...-miles-on.html
trini_per4mance is offline   Reply With Quote
Old 08-03-2009, 08:16 PM   #12
Yeah, I have a metallic clanking sound when I step on my brakes, but doesn't happen all the time. Only happens when it's changing directions, for example, if I reverse, then go forward and brake, it'll produce the sound.
Old 08-03-2009, 09:11 PM   #13
trini_per4mance
That sound you are hearing, could be the spring on the strut making that noise. It's nothing to worry about though.
Old 08-04-2009, 04:44 AM   #14
Aothachos
Drives: 2008 Yaris Sedan
Send a message via AIM to Aothachos Send a message via Yahoo to Aothachos
Well when i go into reverse and brake i hear a click in my brakes thats all, otherwise braking any other way i hear nothing, its only in reverse for some reason =/ I'm not sure what that is
Aothachos is offline   Reply With Quote
Old 08-04-2009, 05:19 AM   #15
Could be either that, or what my friend said about the pads just shifting, which is also nothing to worry about. Thanks.
Old 08-04-2009, 03:55 PM   #16
marcus
toyota
marcus's Avatar
men hope so...its not that bad i hear it once in a while not all the time.
Old 04-19-2010, 06:10 PM   #17
Lucas13
Drives: 07 Yaris LB
I’m having this type of noise, when Im going very slow to park facing forward and apply the brake, it happens also when I brake a little bit hard I can hear the noise and feel some vibration on the floor, My mechanic checked the control arms and there is some unusual play on them.
Lucas13 is offline   Reply With Quote
Old 04-19-2010, 06:56 PM   #18
captaincrunch
Chris
captaincrunch's Avatar
When you brake hard, how the the pedal feel?
captaincrunch is offline   Reply With Quote
Front end mask RocknRollRon Items for Sale by private party 7 09-02-2007 07:12 AM
Bra or front end protector? Yaris S N9QGS Cosmetic Modifications (Exterior/Interior) 6 07-13-2007 09:29 AM
FT: Polar white Front End in So. Cal Walter Items for Sale by private party 33 01-16-2007 01:11 AM
For trade, polar white front end Walter California 0 01-09-2007 12:38 AM
Front End Alignment after Spring Install? OK Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-26-2006 08:46 PM
