Old 01-11-2011, 02:03 AM   #1
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Water to Air Intercoolers
I found this type of intecooler on e-bay http://cgi.ebay.co.uk/CHARGE-COOLER-...item35ae7c5be9 for £100.
I never had experience with these type of intercooler but they look teasing...
Please comment as I am really interested what the experts say on this?
Old 01-11-2011, 07:44 AM   #2
Tamago
Tamago's Avatar
Drives: ZZW30
you'll need a water pump to recirculate and "radiator" (also known as a heat exchanger) mounted up front to cool the water down. the Mid engine guys use them because they're much more consistent than an air/air, and are more compact in tight engine bays. i don't think it'd be very advantageous on a front engined car, since you have the advantage of airflow already.
Old 01-11-2011, 10:07 PM   #3
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
i would recommend staying air to air.
i debated going water to air on my wrx but i decided against it.
it adds alot of extra weight of the air to air, more complicated, you need a pump, temp sensors to run fans, you need a decent size rad to cool down the water. an overflow tank for when the system heats up and pressurizes. and if it heat soaks, you need to cool the whole system. the added benefit is alot shorter intake track, and if done properly it can be good.
that's my opinion.
if you do plan on venturing this route these guys have everything you need to do it.
www.siliconeintakes.com
Scubaru Steve is offline   Reply With Quote
Old 01-13-2011, 12:56 AM   #4
turboecho2005
turboecho2005's Avatar
Drives: 2005 Toyota Echo
I also recommend an Air to Air. Just for the simplicity and ease to work with. Last thing you want to be doing is troubleshooting coolant lines, pump, heat exchangers...
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp
1987 Nissan Maxima - 40,000 original miles - Slammed
1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater
1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored
1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress
turboecho2005 is offline   Reply With Quote
Old 01-13-2011, 02:13 AM   #5
Parmas
Parmas's Avatar
I got the idea... I am not ready for these problems.....
I am scraping the idea.
Thanks for the comments
Old 01-13-2011, 02:32 AM   #6
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
I was always of the understanding that air to air intercoolers are the most efficient.
pimp my yaris is offline   Reply With Quote
Old 01-13-2011, 11:22 AM   #7
IF you're getting the good intake temps you want when you tune, there is no need to make a change.
I have a pretty small intercooler, and my tuner is very happy with the set up. I know he would suggest a change if he thought I could get a better result.
Old 01-13-2011, 01:31 PM   #8
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
The thermal capacity for air to water is much greater than that of air to air. Air to Air systems are used for cost and complexity reasons vs air to water. For simplicity sake I would go air to air and be done with it but both systems have advantages.
The one reason I don't like fmic is that they add lots and lots of piping to the system and for a turbo/centri supercharger that means lots and lots of volume of space to to fill which in turn either drops boost # or increases turbo lag as well as engine response lag depending on where the maf is placed.
With the yaris having small engine bay im sure either system will work fine.
Intake Systems Decision Maker.. Blenjar Performance Modifications 25 09-15-2007 11:07 PM
