Old 01-17-2011, 06:18 PM   #1
DIY: lowering the Yaris steering wheel
Problem: Racing seats make the steering wheel too high.
Solution: unbolt the steering column, lower it a bit, and bolt in some inserts. I cut some pieces from 1.5" square steel tubing, then drilled a hole in one end and a slot in the other. The slot makes it a little easier to slide it onto the upper stud that used to secure the steering column. The result is pretty low (great for racing), 1" might be a little better for street driving and getting in and out of the car.
Much better!
Anyone Else Hate The Yaris Steering Wheel? PhilD424 Cosmetic Modifications (Exterior/Interior) 55 01-24-2011 08:08 AM
US '09 5-Door LB: How do you remove the steering wheel? IsLNdbOi DIY / Maintenance / Service 5 06-30-2010 12:50 AM
