Old 01-24-2011, 07:41 PM   #1
Focus_Sh1ft
Focus_Sh1ft's Avatar
Foglight Power Source
I need a location to draw 12 volts (preferably in ACC) for my foglights. Until yesterday I had it hooked up to the ACC spot in most tutorials (also part of the fuel pump fused circuit), however it suddenly stopped working. I'm looking to use an add-a-fuse on the fuse panel, but don't know which spot will support them.
Since our bulbs use 80W, am I correct in assuming the amperage is 80/12 = 6.5ish amps?
Old 01-24-2011, 10:19 PM   #2
You can use connector 4F - Pin 5, which is a light blue wire. It is the ACC switched feed to the CIG and ACC fuses and is fed by the 25A AM2 fuse.
Correct on the current draw calc.
Old 01-24-2011, 10:25 PM   #3
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Why not directly off the battery?
Old 01-25-2011, 07:58 AM   #4
Vinceb
Drives: 2008 5 Speed Sedan
It could be the fact that I've got a Canadian version of the Yaris sedan, but in the engine bay, coming off the headlight harness is a second plug that has 3 (maybe 4) pins on it on. isn't this pre-wired for fog lights? - I haven't added mine yet but hope to this spring
Vinceb is offline   Reply With Quote
Old 01-25-2011, 10:12 AM   #5
The US yaris is the same for the under hood wiring. I believe he's working on the coil side (switch side) of the fog light circuit, as opposed to the contact side (bulb side). I also think that he used the harness included with the aftermarket fogs, as opposed to the OEM wiring method.
Old 01-25-2011, 02:54 PM   #6
Focus_Sh1ft
I'm actually not even using a relay. Just +12v from ACC to a switch out to the fogs.
Thanks CTScott. Your electrical genius never ceases to amaze me.
Old 01-26-2011, 05:57 AM   #7
amalrd
Drives: Toyota Belta SCP92 Chasis
Hi I have a Toyota BELTA(SCP92, 1300cc, X grade) car. Need to fix the fog lights. Can I get the correct wiring points & directions how to get the switch connected. Can some one help me out.Tks.
Amal
amalrd is offline   Reply With Quote
Old 01-26-2011, 09:02 AM   #8
Amal
Do you have the OEM fog lights or an aftermarket kit?
Removal of the Factory Integrated Source sqcomp In Car Entertainment + Electronics (audio / video / alarm) 7 08-24-2010 01:44 AM
Finding a usable power source Taiyaki In Car Entertainment + Electronics (audio / video / alarm) 4 05-25-2009 10:37 PM
Possible Revolutionary Power Source...Aquygen nsmitchell General Yaris / Vitz Discussion 7 06-20-2007 08:32 AM
POWER WINDOW POWER SOURCE IN DOOR PANEL? mrrock DIY / Maintenance / Service 5 03-21-2007 07:27 PM
