Old 02-26-2011, 07:52 AM   #1
blacks
Drives: toyota yaris sedan
Ignition
Hi
Last night I started my car to go home from work and I accidentally took the key from the ignition contact and to my knowing the car was still running.
Is that normal and then when I tried to drive home without the key in the ignition it didnt stoped
Did this kind of thing happen to anyone or I'm the first and I was kinda scared because if a theift come he could easily steal my car is there anything I can do or is it normal and I should leave it like that
Is this normal did this ever happen to anyone please let me know
blacks is offline   Reply With Quote
Old 02-26-2011, 08:24 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
how old is you car, how many miles/km and did you turn it back, or just pull it out?
Old 02-26-2011, 10:50 AM   #3
blacks
My Car is a 2007 Toyota yaris sedan version
It has 70,000 KM on it and no I didn't turn the key back it was in the ignition and I pulled it out by mistake
Old 02-27-2011, 05:50 PM   #4
blacks
Hi
Can anyone tell me what to do with my Ignition problem please
Old 02-27-2011, 06:55 PM   #5
swidd
Drives: Yaris HB
There was another user on the forum, "trinity performance 4" or a combination of letters similar to that, who had trouble with his ignition switch/clutch switch after 400,000+ miles.
Don't know what came of his request for help, but here it is: http://www.yarisworld.com/forums/showthread.php?t=30758
Obvious answer is take it to the dealer and let them figure it out. Probably falls under the 100,000 mile powertrain warranty thing. If it didn't happen again I wouldn't worry about it...
Old 02-27-2011, 08:26 PM   #6
The keyswitch has a mechanism that locks the pins when the key is turned to prevent pulling it out in any position except off. I haven't pulled an ignition switch apart to know if this problem is repairable or if you will have to replace the switch (and the keys and lock cylinders) to resolve it.
I don't think that it is a security issue, as you will probably find that you can't insert something other than key and start the car.
Old 02-28-2011, 06:11 AM   #7
blacks
@CTscott so what do You propose I do ?
@Swidd thank you for the info
Old 02-28-2011, 06:37 AM   #8
I would test it to verify that the switch won't turn unless the key is inserted. If it does not, then you don't have to worry about it being easily stolen. In that case, considering how much of a hassle it would be to change all of the lock cylinders, I would leave it as is.
Old 02-28-2011, 01:59 PM   #9
blacks
@ Ctscott
How do you test the switch to make sure that if the key is not inserted it won't start
Old 02-28-2011, 02:06 PM   #10
@ Ctscott
Either stick the key half way in and try to turn it, or stick a key from another Toyota in and try to turn it.
Old 03-01-2011, 03:53 PM   #11
blacks
@CTScott thank you i'll try it on friday because my car is beeing repainted now
Old 03-07-2011, 06:56 PM   #12
blacks
@CTScott
Hi
I tried what you told me i sticked the key half way in and it didn't turn there was like a lock it couldn't turn anymore
I don't really have another toyota key to try the other thing you told me
So what does that mean now ctscott ?
Old 03-07-2011, 09:14 PM   #13
RawrDaddy
Drives: 2007
@CTScott
Hi
im guessing he was trying to see if your ignition was.. "loose"
aka - anything could turn it on.
but since it looks like it still requires your key - security wise it doesnt look like your in too much danger.only problem im seeing is that you make sure you turn the key and turn the car off
i think scott was kinda leaning towards the same thing
RawrDaddy is offline   Reply With Quote
Old 03-07-2011, 09:21 PM   #14
^Exactly. Basically no one can easily steal your car, so you are fine from a security standpoint.
Old 03-08-2011, 04:20 AM   #15
blacks
@CTScott but is it normal that the key can come out ?
Old 03-08-2011, 06:54 AM   #16
It's not normal, but it really won't hurt anything.
Old 03-08-2011, 02:43 PM   #17
blacks
Ok thank you
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
Door trigger for Rear Right RR door missing enve1160 In Car Entertainment + Electronics (audio / video / alarm) 12 12-29-2010 10:14 PM
FS: Motec M4 Standalone ECU w/ Ignition Expander Biggie™ Items for Sale by private party 6 10-20-2009 02:36 PM
Moving the Ignition To The Left? MadMax Cosmetic Modifications (Exterior/Interior) 4 10-02-2009 11:57 PM
Ignition locks? Blowtorch DIY / Maintenance / Service 4 05-13-2009 12:26 PM
