![]() Drives: '09 Yaris,Sedan,1.5L,Manual Join Date: Mar 2011
Pulsating Vibration
My ’09 yaris sedan has a pulsating vibration only in 5th gear going 60-65mph (2500-2800 RPM) range.
I thought I saw a TSB on some kind of vibration before but now I can’t find it. When I push the clutch in, the slight vibration goes away. So it isn’t an off balance wheel or a bad tire. I’m thinking it has to do with the engine or transmission, since it goes away when the car is in neutral. The vibration is present on acceleration and deceleration. Anyone have any ideas as what would be causing the pulsating vibration. It pulsates about ever 1-1.5 seconds, very slight vibration that you can feel through the whole car. Not the steering wheel, but on the floor pans and seats.Thanks in advance for any input. Its greatly appreciated. |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
could be a natural harmonic? I don't know why you rule out alignment issue or tire balance.
I ruled that out because it is related to RPM's. If I push the clutch in, the vibration goes away.
When I accelerate up to 70mph, the vibration is there, then push the clutch in and coast down to 55mph, no vibration. Speed back up to 70, vibration accelerating, keep the clutch engaged and cost down to 55, the vibration is still there. Seems like a lot of other people are having the same problem. I found this thread after doing some more searching. http://www.yarisworld.com/forums/sho...ight=vibration |
![]() ![]() ![]() Drives: 07 Yaris Sedan, Auto Join Date: Jun 2010
there has been a few threads on this. my 07 sedan does the same thing around 60 mph.
PsychMobile
Drives: '10 Yaris 5Dr Blazing Blue Join Date: Oct 2010
My car has the vibration too. I just ignore it after I realized that 60mph vibration comes standard with all Yaris.
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
+1. Normal engine harmonics. My Tanabe exhaust "fixed" mine!
| 2000 R.P.M Vibration | dallas | General Yaris / Vitz Discussion | 35 | 09-01-2025 10:18 AM |
| steering wheel slight vibration high speed??? | marcus | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 32 | 10-01-2012 07:36 PM |
| How much engine vibration is normal? | Frankd1 | DIY / Maintenance / Service | 6 | 10-14-2009 10:11 PM |
| A/C vibration from supercharged engine? | Morgan | Forced Induction Forum | 16 | 08-01-2009 01:47 AM |
| Post-rotation vibration | kurokoma-kun | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 09-15-2007 06:02 PM |
