![]() Drives: 2010 Yaris Sedan Join Date: Mar 2011
tein S tech Spring question?
just wanted to make sure the Tien S tech Spring model# NPC91L which is meant for the 07+ Yaris 3drs will work w/ my 2010 Yaris Sedan? I believe its suppose to be a 1.9 inch drop but considering my cars a sedan what do you guys think will be the end result in the drop w/ my heavier sedan? Will I also need to remove my wiper assembly like ive read in the DIY section since mines a sedan? Thanks
First thing's first. The sedan is the lighter of the three Yarii. However, something about it makes it have a lower drop on the same set of springs.
Second, it'll fit. I'm running the S.Tech's. Drop is approximately 2.1" Here what mine looks like on 16" rims with 205/45/16 tires.
Oh, I have coil spacers/lifter in the rear, so it's raised about 1/2".
Thanks for the response and the pic's, looks nice!!!
I believe tho that the 2.1 drop is for the S tech Springs made for the 5 door, the 3dr Stech springs are suppposebly a 1.9 inch drop! Wondering if there will be a prob using the 3dr springs on my sedan if itll be more of a drop or less of a drop... Did you have to remove you're wipers when you were doing your spring install? Thanks again! |
The box says "3-door only". lol. There's no difference. Also, trust me, the sedan drops like the 5-door, not sure why since the sedan is lighter. I wasn't that knowledgeable when my suspension was installed, but I believe the cowl was removed. Since then, I've became more knowledgeable. lol. I'm installing suspension parts on Si's now. hahahaha
This was done back in the beginning of 07, so that's why my memory is a little fuzzy. hahaha.
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
^ hey how does it ride?
i've been looking at them...you still on stock dampers??
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
It rides okay. I have the TRD Sportivo shocks. My family and friends (who are not into cars) hate the ride tho. They find it too "bouncy" while I say it could be a little stiffer/firmer. hahahaha
| Need your help installing Tein Basic coilovers for rear canot get spring seated | DeathBeard | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 09-01-2010 11:46 AM |
| Question about cutting the rear spring perches | YarisSedan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 07-20-2010 10:22 PM |
| For the TEIN S tech users any sagging issues? | marcus | Performance Modifications | 7 | 01-28-2010 04:06 PM |
| Hyperco 5.5" single pigtail rear spring test | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 06-15-2009 10:11 AM |
