Old 08-03-2009, 06:04 AM   #1
Jochen
Jochen's Avatar
Drives: Yaris D-4D
Changing to LED-bulbs
I've changed every interior bulb to LED-bulbs so I got that nice white (a little blue) look.
The difference between LED-bulbs (in front) and original bulbs (middle)
This one is a little more blueish than the lights in front.
Before and after:
Even changed the one in the trunk
And finally, the license plate
Jochen is offline   Reply With Quote
Old 08-03-2009, 06:14 AM   #2
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
nice! I hope to do that too some day, but I'm working on strictly performance right now...
Old 08-03-2009, 12:41 PM   #3
Sparks Toyota-TRD
Drives: Toyota/Scion
That looks good!
Tim
Sparks Toyota-TRD is offline   Reply With Quote
Old 08-03-2009, 12:43 PM   #4
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
I changed them as well they seem to be less bright then the stock ones but i still like them
Originally Posted by sw07gt
Old 08-04-2009, 10:18 PM   #5
Norkotik
Drives: Yaris
PRETTY TIGHT
Norkotik is offline   Reply With Quote
Old 08-04-2009, 11:09 PM   #6
kac
kac's Avatar
Drives: 2009 Meteorite 3dr
very nice results. What LEDs did you buy? Where did you get 'em? How much did they cost? Was it an easy change?
Old 08-05-2009, 12:41 AM   #7
enobmort42
First time DIYer
enobmort42's Avatar
Drives: '07 LB Polar White
Send a message via AIM to enobmort42
i just placed my order a little while ago through autolumination.com to do my parking, brake, reverse, turns, side markers, dome/map/trunk, and license plate all in LED.. it cost me about $85-90 i think?
LED tails - debadged - 17" wheels - LED door handles - Painted Headlights - 30/35% tint - Blue LED Interior - DIY Cruise Control - Python 460HP Alarm - DIY Power Locks - K&N CAI - Lowering Springs
enobmort42 is offline   Reply With Quote
Old 08-05-2009, 01:08 AM   #8
IsLNdbOi
IsLNdbOi's Avatar
I've changed all of my interior lights too. Got mine from VLEDs. Still waiting for someone to try using a white, 4" CFL in place of the rear license plate light.
Old 08-05-2009, 03:55 AM   #9
Jochen
Jochen's Avatar
Drives: Yaris D-4D
It's pretty easy, but here's a small DIY.
I used T10 bulbs like this for the map lights and license plate (about 6$ for 2):
A bulb like this for the dome light (31mm) and the trunk (37mm). Note that these are 2 different sizes. (about 10$ each)
Use a screwdriver at those 4 points, just pull the lights out (no turning or pushing, just pulling)
Use a screwdriver at those 2 points
Use a screwdriver at this side, plug it out by pushing the clip at the connector, change the bulb, plug it in
And that's how easy it is.
The license plate was a bit trickier. There's 2 clips at the sides you have to pull inwards and then pull it down. It doesn't come out that easy.
Then just turn the socket en pull it out, change bulb and put everything back.
Old 08-05-2009, 12:19 PM   #10
kac
kac's Avatar
Nice little DIY, this is something I would like to do in the near future.
rock On!
Old 08-22-2009, 10:36 PM   #11
mario.guzman
mario.guzman's Avatar
Drives: '07 Toyota Yaris Hatchback
LED lights
I just wanted to know where you bought those LED lights and if they are simple to install. I have an '08 Yaris Sedan that I'd like to do that too. My main focus right now is to change the back lights that shine on the License Plate itself to be LED.
So, again, I'd like to know where I can buy them, if they are easy to install and if I need to buy anything else. I'm assuming it's just the bulb you change for everything? Also, around what range of price should I be looking in? Thanks!!!
Mario G.
Riverside, CA
mario.guzman is offline   Reply With Quote
Old 08-23-2009, 06:42 AM   #12
etheliters
etheliters's Avatar
Drives: 07 yaris hatch
great write up. autoillumination...
etheliters is offline   Reply With Quote
Old 08-24-2009, 01:35 PM   #13
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I was going to do the same thing. The first ones I bought are some for the license plate, but I'm having a hard time getting to the bulbs to replace them :( I'll look for those 2 clips you talk about and see if I can get it.
Old 08-24-2009, 03:07 PM   #14
Jochen
Jochen's Avatar
Drives: Yaris D-4D
Don't use screwdrivers but small pliers, so you can hold the clips and pull it. You have to wiggle the whole thing a bit. Pull a bit on the left, a bit on the right, ...
I also had to remove my license plate because I couldn't pull the whole thing down.
Oh, and a small tip: Test the light before you put everything back in
ps. Sorry for the cellphone pic, our camera is broken.
Old 08-24-2009, 04:24 PM   #15
RedRide
RedRide's Avatar
Very useful DIY.
Personally, I just (today) installed some "Polarg M4 B1 hyird" hyper white bulbs in my map lights.
I just happend to have them on hand (I use them in my other car) and I already installed them in my front parking and license plate lights.
However, I just ordered a led bulb for the dome light. The DIY informed me what size (31mm) to get.
Old 08-25-2009, 11:43 AM   #16
47_MasoN_47
Hmm I'm guessing you have the liftback? I don't see those clips anywhere on the sedan :(
Old 08-25-2009, 12:59 PM   #17
Tamago
Tamago's Avatar
Drives: UZJ100
www.superbrightleds.com
Old 08-25-2009, 02:39 PM   #18
Jochen
Jochen's Avatar
Drives: Yaris D-4D
Yes, it's a hatchback.
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 01:59 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 02:50 AM
Led taillight bulbs casterqc Cosmetic Modifications (Exterior/Interior) 27 09-15-2007 02:48 AM
