Old 05-09-2011, 07:58 PM   #1
746watts
Drives: 2014 yaris hybrid
Right Headlight not working, not bulb/fuse
Not the bulb, not the fuse. Here is what I found with my 12V circuit tester.
With lights switched OFF
Right bulb 3-pin pulled off bulb, all terminals have 12volts (green,blue & Black wires), green at 9 o'clock, blue at 12 o'clock, black at 3 o'clock.
Left 3-pin (which is working fine on DIM & HEADS), Brown at 9 o'clock, Green at 12 o'clock, Grey at 3 o'clock. Grey 12v. other two 0v.
With lights at DIM
Right 3-pin, Green 12v, Blue 0v, Black 12v
Left 3-pin, Grey 12v. other two 0v
With lights at HEADS
Right 3-pin, Green 0v, Blue 12v, Black 12v.
Left 3-oin, Grey 12v, other two 0v.
The fuses are 10amp and are fine and there is 12v on the input side of both fuses.
And sticking the bulb into my Landcruiser it works perfectly, so I've double checked the bulb and no fuses are blowing, just no DIM or HEADS on the right bulb.
The car is a 08 with 148,000 kms I've had from new.
Any ideas before I have to go to the dealers?
746watts is offline   Reply With Quote
DIY Projector/HID (sedan) Brian DIY / Maintenance / Service 145 02-05-2012 05:13 AM
Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison CTScott DIY / Maintenance / Service 54 02-14-2011 09:58 AM
How To Smoked Sedan Headlight -DIY zulhizainL902S DIY / Maintenance / Service 26 01-14-2011 03:12 AM
Glassylite Headlight Restoration Kit TEHxFALLEN V1.2 Photo-Video-Media Gallery 1 07-03-2010 01:51 AM
HELP! I detailed my interior, and now having a headlight issue! Astroman DIY / Maintenance / Service 4 06-08-2010 07:51 PM
