Old 05-16-2011, 02:14 PM   #1
ConnerSportsRacers
Drives: B-Spec Prep
SCCA B-Spec Prep
The Yaris looks like it may be competitive.
Minimum weight of 2250 lbs and a front brake rotor of 258mm
The Mazda is 2130 lbs and 258mm rotors
The Honda is 2400 lbs with 262mm rotors
If the engine is peppy, it will hold its own
Roll cage 2011 rules is:
.080 Plate at aprx. 3.15 lbs/sq'ft
1.5" x .095 DOM Tube at 1.426 lbs/ft
1.625" DOM looks like only .065 & .095 is avalible
Alloy 4130 Tube 1.625" x .083 airframe tube @ 1.367 lbs/ft
Use 4130 Plate & Gussetts also
Shocks & Spring with a "bolt on" camber plate is the only mods allowed
My web ConnerSR.com has the rules posted & you can copy them to print.
If anyone in the South East would like a Roll Cage for B-Spec, call anytime
Thanks, Craig
ConnerSportsRacers is offline   Reply With Quote
Old 05-16-2011, 02:20 PM   #2
Jason@SportsCar
Thanks, Craig
http://www.yarisworld.com/forums/showthread.php?t=34377
Tags
scca b-spec ssc
2011 NYR SCCA AutoX Schedule NYR Solo Tracking, Racing, Auto-X Forum 0 04-06-2011 02:57 AM
2011 NYR SCCA AutoX Schedule NYR Solo NY / NJ/ CT / PA 0 04-06-2011 02:56 AM
12/20/08 Buddy Club USA 5th Anniversary Clearance SALE DuckinOut California 3 12-18-2008 01:25 AM
Benefits of SCCA rstb88 Tracking, Racing, Auto-X Forum 8 12-01-2008 03:43 PM
bodykits for USDM spec? cali yaris Cosmetic Modifications (Exterior/Interior) 12 05-31-2007 09:04 AM
